manoj.patil.1974
I recently replaced my headlight bults with a halogen 100/130 Watts bulbs. This means that my total headlight bulb watt load would be 200Watts or 260Watts at high beam.
I have connected these new bulbs to 2 bran new Relay contacts with separate thick high current wirings via extra external fuses. This is to ensure that I dont overheat or burn the original car wiring and also extra fuse for protection.
I have connected one of the contacts of relay to the +ve terminal of battery and other contact to the right side bulbs. The same wiring repeated for the other relay to left side bulb.
My question, when the engine is running at full speed, who would be providing current to the bulbs , is it the battery or the alternator ?
I have a Honda City 1.3 liter India version car. I assume ( i dont know how to find it out) that my alternator capacity is 60 Amps. At 260Watts, my bulbs would need just over 20 Amps. Since I dont have any other load ( A/C off, no audio system), the 20 Amps should be ok for the alternator.....
But with my connections, will the alternator be able to provide current to my bulbs ? I have this doubt because I have connected my bulbs to the +ve terminal of battery.
I feel that the alternator will provide just enough charging current to the battery and may not be able to sense that there is extra bulb load... I dont know how much maximum current the regulator of the alternator would provide to the battery for charging.. I would guess it would not be 20Amps ( as the battery itself is a 40Ah capacity)....
So if I am not getting 20Amps from my alternator, this means my battery is being drained at a higher rate than the current supplied to charge the battery and eventually my battery would be discharged... correct ???
If the above is true, what connection changes do I have to do ? Is there a way I connect my bulbs directly to the alternator at the bridge rectified output point ( i.e before the charging regulator circuit) ???
My headbulbs light up when the engine is off or on.... so this verifies that there are no obvious connection problems... but I have realised that the headlights are a bit dimm on highway driving.... they are not too dim but somehow I dont get a feel of a 130Watts high beam.... the light output does not give a enough visibilty feel...
_________________
_________________
