Headset Fix Internal Wiring Question
ashuriexin
I'm trying to fix my headset(left side) and I don't understand how the wiring works. Can anyone help me which color of the wire should I connect the board(AG, R, B, G, R, V). I tried to research it but I'm really confused.
Thank you!
Check with a ohmmeter which wire is connected to which pin from the across side, since they are connected parallel, you need to connect the same colors to the same pins. But you need to burn the cable tips because its though to solder headphone cables.
Good luck
