bitem2k said:Hi, dch222
thanks.
Never seen those, but i will look into it.
What about a 12v Car battery?
bitem2k said:Would nichrome wire be suitable?
bitem2k said:Nice one mate, thanks very much.
Would this Cause the actual battery to be heated dangerously hot? Like a short?
The actual heat in the resistance is 'W = V x I'.
bitem2k said:If I wrapped the wire around some metal, would the metal be dangerous to touch, electrically speaking? (not temperature)
I.e. if you touched the water inside a kettle after just turning it on, would you be electrocuted?
Does the battery get as hot as the wire?
bitem2k said:I have seen some vague articles about heating a cup of water with several AA cells.
So if I were to heat the wire to upwards of 100 degrees
would I would have to insulate the wire.
If the battery gets as hot as the wire is this dangerous?
If not AA cells , what about 12V car battery?
vaporizers.ca said:Blow Through Product Function Allows for Quick Heating and Inhalation
Battery is external, uses cord to attach to Oxygen unit
bitem2k said:If the battery is external and the unit heats up to 400 degrees F, how can that be safe?
Sceadwian said:BTW a good source for high power handling nichrome wire is... toasters! =) Insulating it is a bit if a problem though.
