Hello, i need formula for if IF transformer 42IF123-RC to design in ltspice
Hello
can somebody help me
for IF transformer
42IF123-RC i need to resonate at 10.7Mhz, i want to design in Ltspice
i read one Post here, but i dont understand
i dont know the formula, for inductor in ltspice
here my circuit in ltspice
118820
The capacitor is 4.7pF + 5pF = 5.2pF
From 1-3 is 4.5uH (3.2 to 5.7uH)
There is no 4k resistor inside.
1-2 = 5 turns
2-3 = 9 turns
1-3 = 14 turns 4.5uH
4=6 = 2 turns
The formula for inductance and turns ratio is turns^2 (turns squared)
We know that 14 turns = 4.5uH.
You need to work out the inductance for 1-2, 2-3, and 4-6. Then plug them into spice.
You have the phasing of 1-2 & 2-3 so the inductance will add not substract so that is good.
I hope this helps. RonS.
Hello Rons
thanks for help
i realy dont understand
PLEASE can you show me one example?
i dont want to bother nobody here
so 1-3 is 4.5uH, come 14 turns = 4.5uH
i get 4.5uH ^ 2 we get 2025uh
I rely dont know, how come 14 TURNS = 4.5uH
:banghead:
oh man can you show me example please...……..
thanks
There are 14 turns between pins 1 and 3. Per the datasheet there is 4.5uH between pins 1 and 3.
There are 5 turns between pins 1 and 2, so the inductance between those pins will be 4.5uH x (5/14)^2 = 4.5uH x 0.128 = 0.57uH.
ooh thanks Alec_t
perfect MAN, i understand now
:)and wat about 4-6(2 turns) how i have to calculate this one ? please if you know let me know and i go to build...……..
is like this correct 4.5u / (14/2)^2 = 0.9uH
This is the first time I have ever seen somebody try to simulate an FM radio. Why????
Because turning the "on" knob is hard. lol
I have often SPICE-ed the IF filters to get the bandwidth right. Probably I have done every block of a FM radio many times but never the entire thing.
One thing, I do not have enough computer to do the entire radio. I started with SPICE on a 8088 PC and "if my computer was a little faster". Now with 1000x faster it is too slow.
The crystal filter defines the bandwidth. The simulation program does not know about crystal filters.
What crystal filter?
I think we have exceeded the scope of the question. We just needed to go from data sheet to spice model.
