Hello, Hello!! I'm new around here, would like to introduce myself. My names Jay, I'm a pretty big D.I.Y'er and have done wiring/soldering for a lot of previous costumes but I'm still a newb when it comes to knowing fine electrical. I'm a contractor so I do it all, house wiring plumbing, wood flooring, tile, etc. you name it I'm sure I've done it..
Now here's my concept and I'm 100% open to any ideas or improvements. I'm looking at making a gauntlet and full arm and shoulder medieval looking armor that gets frozen to the touch.
You might be thinking (well buddy you have the wrong forums we do electrical circuits here not magic) Well I'm thinking of using thermoelectric coolers.
https://www.ebay.ca/itm/New-TEC1-12...LH_DefaultDomain_0&hash=item461234c2f7&_uhb=1
Something like that, there 40mm x 40mm and I was thinking of using... as many.. as I need..
I'm willing to buy a dozen to a few.. dozen.
Now I was thinking of setting these up in a way where they are mounted say on my back concealed with a water cooled heat sink also concealed with a rad thats again concealed.
I than run a small copper tube along them on the cold side over and over to collect the.. coldness with a mix of water and antifreeze attach a few pumps with some plastic flex hose going to the armor (connected to copper with fins etc to distribute coldness) and she should be golden. Ill have flex pipes connecting all of the armors together as well.
I will use low noise fans and pumps. (pumps make almost no noise anyway if the air is properly removed from circuit)
I also want to use a few Dewalt 18V XRP battery's to run this while out and about on halloween (but can use something else this is just what I have.. since I'm a contractor LOL!)
I'll also conceal them. I'm going to be a ice mage, so I was probably going to take a "traveler" look and maybe carry a small leather warn looking back pack I could conceal most of everything in.
I havent looked into a lot of the concealing yet but I'll worry about that AFTER I can get a frosty gauntlet. Our halloweens are usually pretty humid so the goal here it to have frost form on the out side of the gauntlet. (I'll even add water to it before going out if I have too, to create ice on the out side of the metal.)
I just dont know where to began with the electrical.. Usually I work with 9v battery's and LED's lol! Whats good is the volts for these guys are 15.2V so thats not too far off from 18volts right?
I was thinking if this works out I might make an A/C suit or arm gauntlets for my mom since she always complains about being too hot.
p.s. between the gauntlet and armor and my skin will be a well insulated suit to protect my skin from freezing. (dont know how well this is going to work but hopefully well enough that it could freeze my skin if not protected well enough)
I figured if I use enough of them and liquid cooled them using the best fans for CFM than the hot side stays cooler and the cold side gets colder.
I can add some pics of my poorly drawn art.. but I dont know if I could do that to you guys. It might be an insult lol.
