Help Appriciated.......PIC AC Volt meter
manojsoorya
I have a code for a PIC AC Volt meter. I need the hex file from this code.... I cant compale, i get some errror messages..... Some one please help me.............and this is the code..
This is the Circuit Diagram Link... : https://obrazki.elektroda.pl/5201592900_1374705285.jpg
include <16F676.h>
device adc=10
fuses INTRC_IO,NOWDT,PUT,NOPROTECT,BROWNOUT,NOMCLR
use delay (clock=4000000) // 4MHz clock
rom  0x3ff={0x3444}
byte PORTA = 0x05
byte PORTC = 0x07
byte TRISA = 0x85
byte TRISC = 0x87
define SPORTA PORTA
define SPORTC PORTC
define  TICKS_BETWEEN_INTERRUPTS      5000 //5000
define  INTERRUPT_OVERHEAD            35
define  TMR1RESET (0xFFFF-(TICKS_BETWEEN_INTERRUPTS-INTERRUPT_OVERHEAD))
const char SegCode[11] = {0x40,0x57,0x22,0x06,0x15,0x0C,0x08,0x56,0x00,0x04,0xFF};
    //                       0    1    2    3    4    5    6    7    8    9
const char Column[3]   = {0x02,0x01,0x04};
static char Segment[3] = {0x7f,0x7f,0x7f};
static unsigned char ColCount=0x00;
void CPU_SETUP(void);
void Display(void);
void HTO7S(unsigned int32 Num);
byte i;
unsigned int32 result;
INT_TIMER1
void Timer1(void)
    set_timer1(TMR1RESET);
    Display();
void main()
    unsigned char i;
    CPU_SETUP();
    while(true)
        result=0;
        for (i=0;i<20;i++)
            set_adc_channel(3);
            delay_ms(1);
            result=result+read_adc();
            //result = 0x3fe;
        HTO7S(result/20);
        delay_ms(200);
void CPU_SETUP()
   setup_comparator(NC_NC_NC_NC);   // not use comparator module
   setup_adc_ports( sAN3 | VSS_VDD);
   setup_adc(ADC_CLOCK_DIV_64);
   TRISA=0b00011000;
   PORTA=0x27;
   TRISC=0b00000000;
   PORTC=0x37;
   setup_timer_1(T1_INTERNAL|T1_DIV_BY_1);
   enable_interrupts(GLOBAL);
   enable_interrupts(INT_TIMER1);
// Display routine
void Display()
    PORTA = 0b00100111;   // off all digits column and Segment G
    PORTC = 0b00111111;   // off segment a-f
    delay_cycles(2);
    if (ColCount>=3)
    ColCount=0;
    SPORTC = Segment[ColCount];
    SPORTA = ((Segment[ColCount] & 0b01000000)>>1) | (Column[ColCount]^0x07);
    ColCount++;
// Convet HEX 2 byte to 7-Segment code
    unsigned int32 res;
    Segment[0]=SegCode[30*Num/10230];
    if (Segment[0]==0x40)
    Segment[0]=0xFF;
    res = 30*Num%10230;
    Segment[1]=SegCode[10*res/10230];
    res=10*res%10230;
    Segment[2]=SegCode[10*res/10230];
A meter like this should be in a plastic box, double insulated, so the user won't get killed.
There not anything stopping you from getting mains voltage to the pic if a part goes bad
starters a small fuse on the testing side would be nice. Then the limt resistor changed from one to two of them so if one blows your still
alive to smell the smoke and unhook the thing.
If you need an AC voltmeter why not go buy one. They're cheap enough and are less likely to kill you. Also how do you plan to calibrate your voltmeter?
Hi ronsimpson
Thank you for your suggession... But I try to make another one exact like this.... So I need to try to test purpuse only. After I Build, I can enclose whole circuit in a plastic case.
Thank you so much.
