Hello,
I am a designer working on a university project with a small understanding of technology building hence why I am turning to ask from you.
I want to create a product which is essentially a scales which measures weight and links to LED lights which will change from red to green at a range of weight. So for example a weight is under or over the inputted "green value" ranges then the LED lights will be red and when in the "green value" range it will be green.
I was thinking of using a arduino to create some kind of smart scales with a linked weight sensor but wanted input of how to make value ranges switch a colour of light.
If you have any reasonable solutions your suggestions are really appreciated and if you would like further clarification, let me know![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
cheers![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
cheers
