mrfunkyjay
Hi all, to begin with, my name is Kelvin. I am now doing research for my final study project, thesis project you could say, and I need to build something based on the concept of Ohm Meter.
This is actually what I want to make, a system that measure exactly how much is the resistance of a resistor. The output would be actuating the motors to carry this resistance into another process which is sorting.
The core research starts now and I am pretty confuse with several things. I have also several things to ask, may be someone could help me out.
1. I planned to make a constant current source. From that, I could get many different Voltage Outputs when this current source is connected in series with varying Resistors.
2. The voltage then, as an input to micro controller to be processed further using voltage comparator.
3. The comparing method would also be one of many research topics I will cover here.
So engineers out there, can you please give comments or may be hints to my project? Thank you very much...
Best regards,
Kelvin - Indonesia
Best regards,
Kelvin - Indonesia
