Only the over-unity folks can help you with that. As I said you can't simultaneously boost both voltage and current, since that means you are getting more output power than the input power, which violates the conservation of energy law.Thanks for your reply sir. Actually then I am planning to step up the voltage using the transformer and boost up the current. But the voltage then will be reduce. Can you suggest any circuit that can boost up both current and voltage proportionally.
