help in one PIC18F452,one accelerometer through spi interface
anilvadnala
Dear Frenz,
I am a student doing project work on PIC18f452.
PIC18f452 connect to a digital accelerometer through SPI interface.
As I am new to embedded and C I felt I made some mistakes in the start of C to read data from Accelerometer.
Below I am giving the data which I wrote..
#include<18f452.h>
#use delay (clock=6000000)
#use rs232 ( baud= 9600, xmit=PIN_C6, rcv= PIN_C7 )
#include<input.c>
#include<spi.h>
//#include<ACCL.h>
VOID main()
unsigned int a,b;
void spi_io(void);
setup_spi(spi_master, spi_slave)
CS=0                          //chip slect low to write to registers
                             //RE2=0
spi_write(0x0b)               // intiates write to control regb
                          //delay_us(130000)
spi_write(0x06)                // write operational mode byte to control regb
a=spi_read(0x8b)              //intiates the read from control reg b
CS=1
delay_us(130000)
spi_write(0x0a)               // intiates write to control regc
                      //CS=1
                     // delay_us(130000)
spi_write(0x00)                 //write operational mode byte to control regc
b=spi_read(0x8a)                //intiates the read from control reg c
CS=1
delay_us(130000)
//spi_write(0x06)
//delay_us(130)
//spi_write(0x14)
//delay_us(130000)
//spi_write(0x07)
//delay_us(130)
//spi_write(0x14)
//delay_us(130000)
//spi_write(0x08)
//delay_us(130)
//spi_write(0x0d)
//delay_us(130000)
//spi_write(0x09)
//delay_us(130)
//spi_write(0x14)
//CS=1                         //chip select high before
//delay_us(130000)
CS=0
// next step is conversion command
[code]
By following the instructions in the data sheet of Accelerometer I wrote this data the 13th page of data sheet given the above instructions and If any one find next conversion command please tell me and find mistakes from above data.
Advance thanks frens
  • kxp841050 digital acc.pdf
