help lrl pcb
thomas33
hi all friends
I like electronics but I'm bad
I need your help
i have a schema for a longrange locators and i like need pcb
I do not know if the diagram is correct
I ask you with great politeness to help me and make me this pcb
thank you for all
  • scheme LRL KING V4.1.2.PDF
You need decoupling caps for all your ICs. Mainly your MCU and op-amps. I also see no power connections on your MCU.
hi dear friend
thank you very much for your answer and your help
I found this on the website longrangelocators
some people who have done project say it is incorrect and incomplete
please friend help i swear i'm beginner in electronics
  • LRL KING V4.1V2 - CADCAM.ZIP
  • WORK_KING LRL V41.rar
Your .zip file is a bunch of Proteus-generated files to manufacture a PCB. If you "save as" or "print as" as .pdf and post the .pdf, more of use will be able to view it. I am not able to open .rar files and about 2 weeks ago spent a lovely evening getting rid of WINRar. Again, please post .pdf or .zip for maximum audience.
Where is the hex file ?
Thank you very much for project King LRL V4.1!
Where is the hex file for King v.4.1?
Please reply me on my E-mail address:
<snip>
Please do not post email addresses out in the open forum. It invites bots and spammers. Use the private messaging tool instead. - A Moderator
Thank you in advance for your answer!
Regards!
hi dear friend
I will recommend some pcb roting tips:
1. Distribute the components on the PCB.
2. Do a good routing planning
3. Check the tracks fit in the defined space
4. Separate the analog part of the digital part.
5. Route the tracks to 45 degrees.
6. Do "sneaking" to the traces
7. Define good retung path.
8.Put copper zones or ground planes to improve the performance of GND and PCB itself
9. Define a track width according to current and space according to voltage
10. Use Routing strategies (minimize usea of vias)
11. Using an adequate routing topology (star or flow)
12.Route the decoupling network optimal
Advertising removed - moderator.
