help me chose a mosfet gate driver
gehan_s
Hi all,
I am planning to make an H-bridge for a DC motor. Here are the specs
Supply voltage range - 12V to 30V
Max current ≈5A
I am planning to use IRF530 and IRF530 and IRF9530 mosfets
The gate driver I have planned to use is this.
Is this and the two mosfets are good choices? Do you have any suggestions?
Thank you !!!!!!!!!
Without seeing the whole circuit it is hard to say, but the driver max voltage is 20 volts and the 30 volts is also to high for the FET gates.
