down_creek
guys....i need your help me to programming the coding to generated the PWM signal using PIC18F4550....
i already build the test board using 8mHz crystal...but no idea how to coding the pic to generated the PWM signal....
what i want to do with my circuit is.....PIC will compare the input voltage from my sensing circuit and will stop the PWM signal if the input voltage is higher than the reference voltage.
for example....3V as reference voltage....if the sensing circuit give the higher input voltage than 3V to pic....pic will stop generate the PWM signal until the voltage is back to 3V....
guys...please help me.....
