Help me convert adc value in kg
Post two measurements:
1: Sensor reading without load (0 Kg)
2: Sensor reading with a known weight on it..
post the weight of the load and the adc reading on both cases.
Progarmming language I am using is c and controller type is avr series atmega 16
My without load adc reading is 325 with load is 750 somting .
Tell me to how to convert adc value into kg.
It is impossible to convert "someting" into kilograms. What is the load.. and what is the raw ADC reading when you put that load to the scale?
1 litre of water is 1 Kg.. put that on the scale and post the ADC reading. Then take the load off and post the ADC reading. Two measurements and that is all it takes to calibrate the scale.
You need atleast two known conditions
a) When there is no load
b) When there is a load
Then you need to convert the input value to the output
actual KG reading = ((ADC reading - ADC min reading) * Kg span) / ADC span ) + Kg minimum reading..
@ Ian Rogers
tell me waht is ADC span and Kg span
in adc reading the value is max or min i placed over there.
where i am getting kg minimum reading
@ Ian Rogers
You answered your own question here..
without load the load cell adc value is 300 something and with load max adc value is 850 something
ADC min = 300 and ADC max = 850... So ADC span = 550
0 kg = 300.. So how many Kg's was load max? If we assume 100Kg then your Kg span will be 100Kg....
@ misterT
@ Ian Rogers
I make this equation according to u. It gives me +ve and -ve value both. The max to max adc value is 1024.
x = read_adc(1);
y = (1024-x);
kg =((1024-x)*50)/y+0;
This is the math then:
x = read_adc(1);
y = (x - 300);
kg = (y*50) / 450;
Be careful with the math. If you use unsigned integers the math will fail very easily. Use floats if you have the processing time available.
[MODNOTE]Deleted Off Topic[/MODNOTE]
Hi shivpsit4
You may have seen this site, but if not, it has a simple explanation of how to convert the ADC reading to Kg: https://www.sparkfun.com/products/10245
Check the video. The description of the calculation begins at about 6:30 and ends at 7:30. That is, it takes about one minute.
Good luck.
John
