i doing my final project on ultrasonic distance meter am using PIC 16f84 ... i did a program but i faced some mistakes in the code's can anyone help and check the program code for me plzzzz !!
this the my program code :- **broken link removed**
You want us to download an EXE file to our computer to check your code. Yeah Right!!
Why not show us the code here?![]()
micro I'm not sure what you're talking about it's a .asm file he posted.
I'll repost it for him.
AM9 for future posts please note that in the advanced posting options you can upload a variety of file types.
;Processor 16F84
errorlevel -302
org 0h ;start from 0000h
goto START ;start main program
org 4h ;interrupt vector
goto isr ;interrupt routine at isr
Pc equ 02h
STATUS equ 03h
TRISA equ 85h
PORTA equ 05h
TRISB equ 86h
PORTB equ 06h
INTCON equ 0bh
OPTN equ 81h
LOOP equ 0Ch
TEMP equ 0Fh
Dist equ 22H
TMR0 equ 01h
Count1 equ 23h
Value equ 24h
lsd equ 25h
Msd equ 26h
bigmsd equ 27h
delay1 equ 28h
delay2 equ 29h
r0 equ 30h
r1 equ 31h
;**********set up the ports A and b**********
START
bsf STATUS,5 ;select bank1
movlw B'00000' ;set PORTA pins as o/p
movwf TRISA ;setting the port A bits
movlw B'00000101' ;move 00000101 to w
movwf TRISB ;setting RB0 as input for interrupt
movlw B'00000000' ;set the prescalar for TMR0 registsr
movwf OPTN ;as 1:2
clrf INTCON ;disable all interrupts
bcf STATUS,5 ;select bank0
;**********check if the switch is closed*********
SWITCH1 btfss PORTB,2 ;read the switch,skip if closed
goto SWITCH1
;***********send 40KHz signal***********
movlw D'10' ;move decimal 10 to w to generate 10 cycles of 40 KHz signal
movwf LOOP ;move decimal 10 to location 0c
movlw b'00100' ;load the initial value to PORTA
movwf PORTA
Send nop ;send 40KHz signal
nop
nop
nop
nop
nop
nop
nop
comf PORTA,F ;toggle RA1/RA2 bits
nop
nop
nop
nop
nop
nop
nop
nop
nop
nop
nop
nop
decfsz LOOP,F ;decrement loop by 1 skip if zero
goto SEND
clrf PORTA
;***********mask delay 1.8ms***************
movlw d'255' ;255x7=1.8ms for mask
movwf delay1
movlw d'7'
movwf delay2
Delay decfsz delay1,f ;delay loop for 1.8ms for mask
goto delay
decfsz delay2,f
goto delay
;****************enable interrupts********************
bsf INTCON,4 ;enable RB0 interrupt
bsf INTCON,7 ;enable global interrupt
;********************start timer****************
clrf TMR0 ;clear TMR0 register
clrf value
movlw d'75' ;move 75 to count1.prescalar is 1:2 so when
;TMR0 reaches
movwf count1 ;75 time taken will be 150us or 0.15ms
;eqt to 1 inch
loop1 movf count1,0 ;move 17 to w
subwf TMR0,0 ;check whether TMR0 is 75
btfss STATUS,0
goto loop1 ;if not 70 go back to loop
clrf TMR0 ;if 75 clear TMR0 and
incf value,f ;increment value
movf value,0
; sublw d'12
; btfss STATUS,2
; goto loop1
Isr movlw d'12' ;1.8ms is equivalent to 12 inches
addwf value,f ;add the eqt distance of mask to final result
; call daa ;call decimal adjust routine
;********************convert the count to decimal***************
Movf value,0 ;load the number to convert
call con_bcd ;convert the tens and units
movf msd,w ;load the tens into w for hundred conversion
;(tens>9)
call con_big ;convert the tens into hundreds (tens>9)
goto display
Over nop
goto over
Con_bcd clrf msd ;clear the msd
Movwf1sd ;move the number to convert into 1sd
Ten movlw d'10' ;load the constant 10
subwf lsd,w ;subtract 10 from 1sd
btfss STATUS,0 ;check if answer negative
goto done ;conversion complete,jump to done
Movwf lsd ;save the answer back in 1sd
incf msd,1 ;increment the msd
goto ten ;do the routine again
Done return ;return to caller
Con_big clrf bigmsd ;clear hundreds
movwf msd ;move the hundreds number to msd
Hund movlw d'10' ;load the constant 10
subwf msd,w ;subtract 10 from msd
goto hundone ;conversion complete, jump to hundred done
movwf msd ;save the answer back in msd
incf bigmsd,1 ;increment the bigmsd
goto hund ;do the routine again
hundone return ;return to caller
;*******************display****************************
Display bsf STATUS,5 ;bank1
clrf TRISA ;set portA all output
movlw d'0'
movwf PORTB ;set portb all output
bcf STATUS,5 ;bank0
movlw d'3' ;disable common anode of both displays
movwf PORTA
Display1 movf lsd,w ;place copy of value in w
andlw 0x0f ;mask off upper nibbe
call table ;get 7 segment data from table and output from port B
movwf PORTB
bcf PORTA,1 ;enable common anodes of led1
call dly5ms ;delay for 5ms
movlw 0xff ;turn off portB
movwf PORTB
bsf PORTA,1 ;disable common anodes of led1
movf msd,w ;exchange upper and lower nibbles of value and put in w
swapf value,w
andlw 0x0f ;mask off upper nibble
andlw b'01111111' ;add decimal point
movwf PORTB ; output from PORTB
bcf PORTA,0 ;enable common anodes for led2
movlw 0xff ;turn off PORTB
movwf PORTB
bsf PORTA,0 ;disable common anodes of led2
goto display1
;*******************decimal adjustment******************
Daa movf value,w ;copy value to q
sublw d'9' ;subtract w from 9
btfsc STATUS,0 ;check for borrow (c=0)
goto daa1 ;no borrow so go to daa1
movlw d'6' ;w>9 so add 6 to value
addwf value,f
Daa1 swapf value,w ;exchange upper and lower nibbles of value and put in w
andlw 0x0f ;mask off upper nibble of w
goto daa2 ;no borrow so go to daa2
movlw 0x60 ;w>0 (90) so add 60 to value
addwf value,f
Daa2 return
;***************5ms delay dynamic display********************
Dly5ms movlw d'10' ;(165*3+5)*10 = 5ms
movwf r0
Dly5ms1 movlw d'165' ;move 165 to w
movwf r1
Dly5ms2 decfsz r1,f
goto dly5ms2
decfsz r0,f
goto dly5ms1
retlw d'0'
;*************************loop up table*****************
Table addwf pc,f
retlw h'c0' ;0
retlw h'f9' ;1
retlw h'a4' ;2
retlw h'b0' ;3
retlw h'99' ;4
retlw h'92' ;5
retlw h'82' ;6
retlw h'f8' ;7
retlw h'80' ;8
retlw h'90' ;9
end
