hotwaterwizard said:Got pictures?
whiz115 said:No i dont...but your are not going to see something special...
it's a typical DIP-8 package with the specific code on it.
thank you for your try... but probably it isn't the one you found![]()
mvs sarma said:hope you may indicate the equipment in which it is used and a rough schematic of the sorroundings as such data might help us to serve you
Regards
Sarma
when you press a button or when the head lights of opposite car is identified, this circuit flashes HIGH beam once and goes back to LOW beam of head lights is it-- may we call it monoshot?whiz115 said:I believe it's a timer 555 or op-amp it's a part of my car Flash relay...
unfortunately i can't make exact identification because my knowledge are
limited. the cirquit has one electrolytic capacitor i think 22μF and 2-3 resistors one of them has high enough resistance i think megaohm..
if it is timer IC i'll try to repair it...no need to buy new relay because i have
spare some 555
