1. 'cos manufacturers make copper-clad pc board.bo100 said:thank you someone Electro..
any body also have another reasons to use copper ??
i want more reasonS
mstechca said:so basically, your question is really going to get you nowhere unless your final product involves exposing the circuit board to the public.
zachtheterrible said:I dont know if solder will stick to other metals?? wont stick to aluminum and steel i know 4sure. back before i knew better i tried making "PCB traces" out of aluminum foil and using steel wire for connecting things :roll: . pure stupidity
Someone Electro said:yep gold is beter (you may have sean ICs whith golden pins) or wnwn beter is mercury infact its a superconductor at room temperature (and wery poisenus)
but its a real shame it isent solid (the only superconductor and the only liqid metal!what a shame)
