help me to complete the ckt. dia. of atmega 8535
sanjpande2010
hi i m sanjeev pursuing btech and i m making my final year project which is about industrial fault monitoring system using atmega 8535.
it protects the dc motor operation from fault conditions like overvoltage, overcurrent, power failure, over tempreature relays means it doesnt show the connection of dc motor and other relays. i got the circut dia which is incomplete so that's why i m asking you to help me as soon as u can. here i m sending oyu the attachment file.
  • vipf_ckt..doc
1) Microsoft Word is not a good schematic capture tool as it has no path to PCB construction.
2) Document properties says it was created last quarter (21 Sept 2009) by "TILAK", modified by "melody main". Is it your work?
3) Since it is your homework, there should be some evidence that you have made a diligent, intelligent effort.
please help me to correct the ckt. dia.
thanks for your concern bt the thing is that i m confused with this ckt. dia. also it is not complete yet. i want to place dc motor connections. could u tell in which pin it will be.
The motor is operated by the I/O pin of your choice. You can use almost any I/O pin that isn't already accounted for.
This pin will not operate your industrial DC motor directly. You will have to design or copy a driver circuit to do the job.
Here's a free good schematic drawing tool...
Also, the '8535 is very old, getting hard to purchase. Use a mega32 or some such.
see avrfreaks.net forum
