Help me.....
include<stdio.h>
void main()
int i;
char map[10]={0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F};
TRISD=0x00;
TRISC=0x00;
TRISB=0X00;
TRISA=0XF0;
RC1=0;
i=0;
while(i<9)
i++;
PORTD=map;
PORTB=0x01;
_delay(196999);
PORTB=0x00;
_delay(196999);
RC1=1;
//RB5=1;
RC0=0;
this program is working in good condition.but i want add a switch control to it.now it is increament continuously.so i want to change this one as when we press the push button
then only the increment happen.
You can use an if structure like this..
while(1)
if(switch==1)
can you please edit my program?am using develoment kit for my programming.same ports are used for many application.so for enable the switch first i want to set RD4==1;my switch is RA4.so how to connect these two thing in my program.when both RA4 and RD7 is high then only the switch will work.
Programming doubt
while(1)
if(switch==1)
am attaching my development kit manual with this..
  • arrangedMicromas&#116.pdf
