help needed for 18f452
ichigo
hi all ,
I badly need advise from you guys . Hope you guys could help me as i am not sure whether what is wrong with my coding . Thxs a million in advance . Currently i am writing a program to run and control direction of my 2 motors through the use H bridge circuit. I am using the PICDEM 2 plus demo board and trying with their built on buttons ,with the 18f452 chip.
After setting and pressing the button that is on the PICDEM board as the input port, the output port which is the CCP1 and CCP2 port(port C, 1 and 2) will cause my 2 motors to run.Beside , I make use of the port D, 0 and 1 as output port to set the motor forward and reverse direction by doing a bsf or a bcf giving a 1 / 0 to my H bridge circuit.
The problem now i faced is that when i pressed the first button (PORTA,4), the 2 motors could move in the same direction. But when i pressed the second button (PORTB,0), only one motor will move while the other motor wont move.I tried compiling the code , but no error is being found. I tried playing around with the code but it still couldnt work. Below will be my code . Pls help and advise me ! Thanks once again .
list p=18f452
#include p18f452.inc
;STARTUP CODE
; declare variables here
Count2 equ 0x000
Count1 equ 0x001
STARTUP CODE
org 00000h ; Reset Vector
goto start
PROG1 CODE
;program code starts here
start
;*****************initialisation*****************
clrf PORTC ;initialise PORTC as output port and clear the port.
movlw b'00000000'
movwf TRISC
clrf PORTD ;initialise PORTD as output port and clear the port.
movlw b'00000000'
movwf TRISD
setf TRISA ;init PORTA as input
clrf PORTB ;initialise PORTB as input port.
movlw b'11111111' ;initialise PORTB as input port.
movwf TRISB ;initialise PORTB as input port.
;*****************main body****************************
clrf T2CON
bcf T2CON,TMR2ON
setf PR2 ;PR2=oxFF
movlw 0x00
movwf CCPR1L
movlw 0x00
movwf CCPR2L
clrf CCP1CON
bsf CCP1CON,CCP1M3
bsf CCP1CON,CCP1M2
bsf CCP1CON,CCP1M0 ;set CCP1 PWM mode
clrf CCP2CON
bsf CCP2CON,CCP2M3
bsf CCP2CON,CCP2M2
bsf CCP2CON,CCP2M1
bsf CCP2CON,CCP2M0 ;set CCP2 PWM mode
;Switch control
;********************Switch 1 **********************
checkSW
bcf PORTD,1 ;set forward direction
bcf PORTD,0 ;set forward direction
btfsc PORTB,0 ;check for sw2.it's normally high, low when pressed
goto wait ;check for sw if sw2 is not pressed.
goto turnon
wait
bcf T2CON,TMR2ON
movlw 0x00
movwf CCPR1L
movlw 0x00
movwf CCPR2L
clrf CCP2CON
clrf CCP1CON
call police
;**************************POLICE*******************************
police
btfsc PORTA,4
goto checkSW2
goto checkSW3
;********************Switch 2 **********************
checkSW2
btfss PORTB,3 ;check for sw.it's normally high, low when pressed
goto wait2 ;check for sw2 if sw is not pressed.
goto turnon2
wait2
bcf T2CON,TMR2ON
movlw 0x00
movwf CCPR1L
movlw 0x00
movwf CCPR2L
clrf CCP2CON
clrf CCP1CON
call police2
police2
btfsc PORTB,0
goto checkSW3
goto checkSW
;********************Switch 3 **********************
checkSW3
btfsc PORTA,4 ;check for sw2.it's normally high, low when pressed
goto wait3 ;check for sw if sw2 is not pressed.
goto turnon3
wait3
bcf T2CON,TMR2ON
movlw 0x00
movwf CCPR1L
movlw 0x00
movwf CCPR2L
clrf CCP2CON
clrf CCP1CON
call police3
;*********************Police 3 *****************************************
police3
btfss PORTB,3
goto checkSW
goto checkSW2
;**************************thief*******************************
thief
btfss PORTB,3
goto continue
goto stop
;******************** when switch 1 is being pressed, speed = 0x9f******************
turnon
btfsc PORTA,4
goto thief
goto stop
continue
setf CCP2CON
setf CCP1CON
bsf T2CON,TMR2ON
bsf PORTD,1 ;set forward direction
bsf PORTD,0 ;set forward direction
movlw 0x9F ;set frequency for CCP1
movwf CCPR1L
movwf CCPR2L
btfsc PORTB,0
goto checkSW
goto turnon
;**************************thief2*******************************
thief2
btfsc PORTA,4
goto continue2
goto stop
;******************* when switch 2 is being pressed, speed = 0x7f******************
turnon2
btfsc PORTB,0
goto thief2
goto stop
continue2
setf CCP2CON
setf CCP1CON
bsf T2CON,TMR2ON
movlw 0x2F
movwf CCPR1L
movlw 0x7F
movwf CCPR2L
btfss PORTB,3
goto checkSW2
goto turnon2
;**************************thief3*******************************
thief3
btfsc PORTB,0
goto continue3
goto stop
;************** when switch 3 is being pressed, speed = 0x5f******************
turnon3
btfss PORTB,3
goto thief3
goto stop
continue3
setf CCP2CON
setf CCP1CON
bsf T2CON,TMR2ON
movlw 0x9F
movwf CCPR1L
movlw 0x9F
movwf CCPR2L
btfsc PORTA,4
goto checkSW3
goto turnon3
;********************Stop **********************
stop
bcf PORTD,0
bcf PORTD,1
clrf CCP2CON
clrf CCP1CON
bcf T2CON,TMR2ON
movlw 0x00 ;set frequency for CCP1
movwf CCPR1L
movwf CCPR2L
goto start
return
end
Hi Ichigo,
please see the continue, continue1 and continue2 subroutines. the comments set forward and the instructions are not similar-- i only presume, the comments are not modified.
	list p=18f452
 	include<p18f452.inc>
; *********************STARTUP CODE **************
Count2 equ 0x000
Count1 equ 0x001
;**********************STARTUP CODE ********************
 goto  start
start
 movlw b'00000000'
 movwf TRISC
 movlw b'00000000'
 movwf TRISD
 clrf  T2CON
 bcf   T2CON,TMR2ON
 setf  PR2 				;PR2=oxFF
 movlw 0x00
 movwf CCPR1L
 movlw 0x00
 movwf CCPR2L
 clrf  CCP1CON
 bsf   CCP1CON,CCP1M3
 bsf   CCP1CON,CCP1M2
 clrf  CCP2CON
 bsf   CCP2CON,CCP2M3
 bsf   CCP2CON,CCP2M2
 bsf   CCP2CON,CCP2M1
;Switch control
checkSW
 btfsc PORTB,0 			;check for sw2.it's normally high,low when pressed
 goto  turnon
wait
 bcf   T2CON,TMR2ON
 movlw 0x00
 movwf CCPR1L
 movlw 0x00
 movwf CCPR2L
 clrf  CCP2CON
 clrf  CCP1CON
 call  police
police
 btfsc PORTA,4
 goto  checkSW2
 goto  checkSW3
checkSW2
 goto  turnon2
wait2
 bcf   T2CON,TMR2ON
 movlw 0x00
 movwf CCPR1L
 movlw 0x00
 movwf CCPR2L
 clrf  CCP2CON
 clrf  CCP1CON
 call  police2
police2
 btfsc PORTB,0
 goto  checkSW3
 goto  checkSW
checkSW3
 goto  turnon3
wait3
 bcf   T2CON,TMR2ON
 movlw 0x00
 movwf CCPR1L
 movlw 0x00
 movwf CCPR2L
 clrf  CCP2CON
 clrf  CCP1CON
 call  police3
;*********************Police3*********************
police3
 btfss PORTB,3
 goto  checkSW
 goto  checkSW2
thief
 btfss PORTB,3
 goto  continue
 goto  stop
;*****when switch 1 is being pressed, speed =0x9f****
turnon
 btfsc PORTA,4
 goto  thief
 goto  stop
continue
 setf  CCP2CON
 setf  CCP1CON
 bsf   T2CON,TMR2ON
 movwf CCPR1L
 movwf CCPR2L
 btfsc PORTB,0
 goto  checkSW
 goto  turnon
thief2
 btfsc PORTA,4
 goto  continue2
 goto  stop
;*******when switch 2 is being pressed, speed = 0x7f ***
turnon2
 btfsc PORTB,0
 goto  thief2
 goto  stop
continue2
 setf  CCP2CON
 setf  CCP1CON
 bsf   T2CON,TMR2ON
 movlw 0x2F
 movwf CCPR1L
 movlw 0x7F
 movwf CCPR2L
 btfss PORTB,3
 goto  checkSW2
 goto  turnon2
thief3
 btfsc PORTB,0
 goto  continue3
 goto  stop
;*****when switch 3 is being pressed, speed = 0x5f ****
turnon3
 btfss PORTB,3
 goto  thief3
 goto  stop
continue3
 setf  CCP2CON
 setf  CCP1CON
 bsf   T2CON,TMR2ON
 movlw 0x9F
 movwf CCPR1L
 movlw 0x9F
 movwf CCPR2L
 btfsc PORTA,4
 goto  checkSW3
 goto  turnon3
stop
 bcf   PORTD,0
 bcf   PORTD,1
 clrf  CCP2CON
 clrf  CCP1CON
 bcf   T2CON,TMR2ON
 movwf CCPR1L
 movwf CCPR2L
 goto  start
 return
 end
please pay partcular attention to continue2 where portd,0 is BCF and portd.1 is BSF
(ONE THING -- I AM NOT EVEN PREMATURE --JUST TRYING TO LEARN-- AS SOMEONE PUT IT --CRITIC CAN'T BE POET)
REGARDS
hi . thanks for ur help . didnt notice that i made an error in the comment . The reason for portd,0 is BCF and portd,1 is BSF is because the h bridge require the 1/0 to control the different direction ( forward /backward ). But this part doesnt seems to work out at all .
