Help needed in servomotor programming !!!
Ashok405
Hey guyz..can any one plz help me in programming a serv motor interfacing with an ATMEL AT89C51.
My servo is capable of rotating only 180' ....any one plz help me with this thing..
I don't understand your problem. RC servos are pretty straightforward. What is it about changing the pulse width to change position that is causing you a problem?
A servos motor is any motor that has feedback. But many times when you say servo you are referring to an "elbow" motor, not a wheel motor that can spin an infinite number of times in either direction. 180 degrees is the maximum range for most servos. Many only have a 90 degree range. And a few have 270 degrees. Very few have multiple rotations (I've never heard of an RC servo that does).
unless you specifically mod it to rotate. most RC servos are pretty easy to.
by the way, I am assuming he means an RC servo. industrial servo motors are a different breed.
I need Servo Programming Help Too!
I am currently working on a project for school. I am using a MC68HCS12 design board by Axiom. My compiler is ICC ImageCraft. The Servos I am using are three Hitec HS-311 & one HS-635HB. I have modified one HS-311 for continuous rotation. From reading most of these posts it looks like I am not able to drive one of these servos from my microcontroller. Do I need a H-bridge? Can I use a L298 to drive the servos? I did get the HS-311 servo to run directly from my board, but is only goes in one direction. I can't get my test program to execute other instructions. It only executes the first one and that is it. I will supply my code down below so you can see what I did. Keep in mind I was trying a variety of different configurations so I commented a lot of code out. So here is my real problem. Getting my code to control the servo in multiple directions or to a certain spot. Another problem I am having is trying to know the angle the servo is at. I connected the potentiometers wire to my ATD and it has a voltage drop of 1.36V to 0.26V and I am using a 10-bit conversion. After calculating, it looks like my resolution is 1.07mV. I am able to read the ATD but my angles are off. I will supply the math I did. I am sure it is off. Also I noticed that these servos only worked at 330HZ for center, 430HZ for clockwise, and 230HZ for counterclockwise. I would really appreciate some help on this. ----------------------------------------------------------------------------------------
/*PWM Test*/
#include <hcs12dp256.h>
#include <lcd.h>
#include <STDIO.H>
void delay_1sec(void)
{//delay_1sec begins
int j,k;
for(j=0;j<=10;j++)
asm("nop");
for(k=0;k<=0x4000;k++)
asm("nop");
}//delay_1sec ends
void init_pwm(void)
{//init_pwm begins
asm("movb #$01,$00A2");//0x00A2 = 0x01; //PWCLK
asm("movb #$01,$00A1");//0x00A1 = 0x01; //PWPOL
asm("movb #$0,$00A5");//0x00A5 = 0x00; //PWCTL
//DDRP = 0xFF; //
//asm("bset $00A0, $01");//0x00A0 = 0x01; //PWEN
//asm("swi");
}//init_pwm ends
void two_thirtyhz(void)
{//three_thirtyhz begins
asm("movb #$45,$00B4");//0x00B4 = 0x45; //PWMPER0
asm("movb #$23,$00BC");//0x00BC = 0x23; //PWDTY0
}//three_thirtyhz ends
void three_thirtyhz(void)
asm("movb #$30,$00B4");//0x00B4 = 0x30; //PWMPER
asm("movb #$15,$00BC");//0x00BC = 0x15; //PWDTY0
void four_thirtyhz(void)
asm("movb #$20,$00B4");//0x00B4 = 0x20; //PWMPER
asm("movb #$10,$00BC");//0x00BC = 0x10; //PWDTY0
void main(void)
{//main begins
//LCDInit(); // initialize LCD
//ADC_int(); //initialize the A to D (ATD) converter
init_pwm (); //initialeze the PWM
setbaud(BAUD9600); // set bits per second rate (baud)to 9600 bits per second
DDRP = 0xFF;
asm("movb #$20,$00B4");//0x00B4 = 0x45; //PWMPER0
asm("movb #$10,$00BC");//0x00BC = 0x23; //PWDTY0
asm("dec $00BC");
asm("dec $00BC");
asm("dec $00BC");
asm("swi");
/*do
four_thirtyhz();
three_thirtyhz();
two_thirtyhz();
read_motor();
delay_1sec();
/while(1);*/
}//main ends
/*ATD Math*/
/*Read Motor*/
#include <STDIO.H>
//#pragma interrupt_handler read_sensor
void read_motor(void)
{//read_motor begins
puts("The angle is: "); //displays The angle is: on the screen
motor();
delay_1sec();
}//read_motor ends
//#pragma interrupt_handler sensor
void motor(void)
{//moto begins
int angle = 0;
ATD0CTL5=0x90;
while((ATD0STAT0 & 0x80)!= 0x80);
angle=((125*ATD0DR0)/256);
ascii(angle);
puts(" degrees");
}//motor ends
//#pragma interrupt_handler ADC_int
void ADC_int(void) //initializes the Analog To Digital Converter
{//ADC_int begin
ATD0CTL2=0xE0;
delay_40us();
ATD0CTL3=0x0A;
ATD0CTL4=0x01; //0x01 = 10bit Conversion
}//ADC_int end
//#pragma interrupt_handler delay_40us
void delay_40us(void)
int i;
for(i=0;i<=0x20;i++)
asm("nop");
//#pragma interrupt_handler delay_1sec
int j,k;
for(j=0;j<=10;j++)
asm("nop");
asm("nop");
