Help needed with NTC resistance calculation
I have a 100k NTC.
I want to be able to calculate its resistance at various temps.
Information supplied with the NTC gives me the following Formula:
R = Ae^B/T
R = the thermistor resistance in Ohms.
T = temperature in Kelvin.
e = natural logarithm base(2.718).
A = approx. 0.0277.
B = 4400
It has been a long time since I used my calculator and I cant get this to work.
Could someone please explain how to use this formula on a calculator.
For the purpose of the explanation could you calculate the resistance at 25 degrees celcius.
Cheers
Luke
If you have BASIC on your computer, write this program:
5 INPUT"DEGREES C=;C
10 A=.0277
20 B=4400
30 T=273+C
40 E=2.71828
50 R=A*E^(B/T)
60 PRINT "R= ";R
70 END
You can download GW-BASIC from my website
I have run the program for these temperatures:
25 deg r=71594
50 deg r=22832.9
75 deg r=8581.3
100 deg r=3677.2
Hi
Thanks for the reply. I think there is something wrong with my formula.
The formula and values I posted were for a 100k @25C NTC.
When I worked it out on my calculator I got 71k just like you did.
This should be 100k. This is why I was questioning myself about my calcuator skills.
Cheers
Luke
