Help on ICDWarn0044: Target has an invalid calibration memory value (0x3FFF)
nicholastyc
Connecting to MPLAB ICD 2
...Connected
Setting Vdd source to MPLAB ICD 2
ICDWarn0020: Invalid target device id (expected=0x7C, read=0x1FF)
ICDWarn0044: Target has an invalid calibration memory value (0x3FFF). Continue?
...Reading ICD Product ID
Running ICD Self Test
...Passed
MPLAB ICD 2 Ready
Having this problem when trying to program the piC12F629 !
Help... i successfully programmed 1 of my same pic, but later on i used another pic, when i wan to program it it pops up """"ICDWarn0044: Target has an invalid calibration memory value (0x3FFF). Continue?"""""
then i put back my another pic, its still the same although i tried it with my 1st pic which was successful, its now also have this warning...
now no matter which pic i put in for programming also appeared to be the same problem.
any help is very much appreaciated.
thanks
;***Title:Led Light Dimmer VERSION 2*********
;*Author:YC THAM*****************************
;**Date:12/6/2008****************************
	ERRORLEVEL -302 ;remove message about using proper bank
	#include <p12f629.inc>
	 __CONFIG   	_CP_OFF & _MCLRE_OFF & _WDT_OFF & _INTRC_OSC_NOCLKOUT & _BODEN_OFF & _CPD_OFF &_PWRTE_OFF
	; __CONFIG _INTRC_OSC_NOCLKOUT & _MCLRE_ON & _WDT_ON & _PWRTE_ON & _BODEN_OFF & _CP_OFF & _CPD_OFF
ORIGINAL_PWM	EQU	H'0020'
COUNT50	EQU	H'0021'
TEMP	EQU	H'0022'
A11	EQU	H'0023'
A21	EQU	H'0024'
GPIO EQU H'0005'
TRISIO	EQU	H'0085'
;******MAIN********
	ORG	0x000
	BCF	STATUS,RP0; bank 0
	CLRF	GPIO;	clear gpio
	MOVLW	07h	;	set to digital I/O
	MOVWF	CMCON	;
	BSF	STATUS,RP0	;	bank 1
	CALL	3FFh;	calibrate the internal oscillator
	MOVWF	OSCCAL;
	MOVLW H'0038';	set the gp3,4,5 as input, gp0,1,2 as output
	MOVWF TRISIO;
	BCF	STATUS,5;bank 0
	BCF	STATUS,C;clear carry flag
START
	BTFSS	GPIO,3		; wait for On/OFF switch input
	GOTO	START;	loop for input
	CALL	PREVIOUS	;restore previous saved PWM
	GOTO	INITIAL_PWM	;go to pwm output loop
INITIAL_PWM
	MOVLW	0x38	; set 0x38input
	MOVWF	GPIO	;
RESTART_PWM
	MOVF	ORIGINAL_PWM,w	; move original_pwm register data to w
	MOVWF	TEMP	;move w to temp register
	BSF	GPIO,0	;turn on output gp0, cool white, HI
	BTFSS	GPIO,1	;check for gp1 condition
	CALL	DELAY	;delay phase shift
	BSF	GPIO,1	;turn on output gp1, warm white, HI
	BTFSS	GPIO,2	;chec for gp2 condition
	BSF	GPIO,2	;turn on output gp2, amber, HI
	MOVLW	d'255';test on the pwm condition
	ADDWF	ORIGINAL_PWM,0;prevent loop on 0 pwm
	BTFSS	STATUS,C;if pwm cycle >0 , loop for the cycles time
	GOTO	LOOP1;skip cycle count loop
	BCF	STATUS,C; clear carry flag
	GOTO	LOOP0;goto cycle count loop
LOOP0
	DECFSZ	TEMP,1		;cycle count HI loop
	GOTO	LOOP0		;
LOOP1
	MOVLW	d'255'		;total possible cycles, 255
	MOVWF	TEMP		;move to temp register for counter loop
	MOVF	ORIGINAL_PWM,w	;move original pwm to w for sub
	SUBWF	TEMP,1		;sub temp with original pwm
	BCF	GPIO,0		;turn gp0 to low
	BTFSC	GPIO,1		;check for gp1 condition
	BCF	GPIO,1		;turn gp1 to low
	BTFSC	GPIO,2		;check for gp2 condition
	BCF	GPIO,2		;turn gp2 to low
	BCF	STATUS,C	;clear carry flag
	MOVLW	d'255';test on pwm condition
	ADDWF	TEMP,0;prevent loop on 0 pwm
	BTFSS STATUS,C;if pwm cycle >0 loop for cycles time
	GOTO LOOP3;skip loop
LOOP2
	DECFSZ	TEMP,1	;loop for cycle count
	GOTO	LOOP2		;
LOOP3
	BTFSS	GPIO,3		;check on switch on/off
	GOTO	START		;back to start if off, continue if on
	BTFSC	GPIO,4		;check for the new pwm cycle changes
	CALL	SHAFT_0		;increase/decrease on pwm cycle
	GOTO	RESTART_PWM	;continue loop for the current condition
;** SUB-ROUTINE*******************************
PREVIOUS:
	BSF	STATUS,5	; bank1
	MOVLW	0x10;eeprom address for saving data
	MOVWF	EEADR;go to address above 0x10
	BSF	EECON1,RD	;read data in address
	MOVF	EEDATA,w	;recall data to w register
	BCF	STATUS,5;bank0
	MOVWF	ORIGINAL_PWM;save to original_pwm register
	RETURN
;**SAVE PWM IN EEPROM********************
SAVE_PWM:
	BSF	STATUS,5; bank 1
	MOVLW	0x10;address to save data
	MOVWF	EEADR;go to addr 0x10
	MOVF	ORIGINAL_PWM,w	;move data on original_pwm to w
	MOVWF	EEDATA;send the data to eeprom
	BSF	EECON1,WREN	;write enable
	BCF	INTCON,GIE	;clear interrupt
	MOVLW	H'0055'	;<eeprom write sequence
	MOVWF	EECON2	;<
	MOVLW	H'00AA' ;<
	MOVWF	EECON2	;<
	BSF	EECON1,WR	;write in progress
LOOP_WR
	BTFSC	EECON1,WR; test for write process complete>?
	GOTO	LOOP_WR;if not complete loop till complete to ensure write successfully
	BSF	INTCON,GIE	;enable interrupt
	BCF	EECON1, WREN;disable write
	BCF	STATUS,5;bank 0
	RETURN
;****DELAY******************************************
DELAY:
	MOVLW	d'50'; number of phase shifting loop
	MOVWF	COUNT50;
COUNT
	DECFSZ	COUNT50,1; loop for 50 cycles
	GOTO	COUNT;
	RETURN
;**DIRECTION***********************************
SHAFT_0:
	CLRF	A11		;clear A11 register
	CLRF	A21		;clear A21 register
	BTFSC	GPIO,4		;check on gp4
	GOTO	SAVEBIT_A11	;goto gp4=1 1st bit
	GOTO	SAVEBIT_A10	;goto gp4=0
SHAFT_1
	BTFSC	GPIO,5		;check on gp5
	GOTO	SAVEBIT_B11	;goto gp5=1 2nd bit
	GOTO	SAVEBIT_B10	;goto gp5=0
SHAFT_2
	GOTO	SAVEBIT_A21	;goto gp4=1 3rd bit
	GOTO	SAVEBIT_A20	;goto gp4=0
SHAFT_3
	GOTO	SAVEBIT_B21	;goto gp5=1 4th bit
	GOTO	SAVEBIT_B20	;goto gp5=0
SAVEBIT_A11
	MOVLW	b'00000001'	;gp4=1 1st bit =1
	MOVWF	A11		;move to register A11
	RLF	A11,1		;rotate left to make 4bit table check up!
	GOTO	SHAFT_1		;back to 2nd bit check
SAVEBIT_A10
	MOVLW	b'00000000'	;gp4=0 1st bit =0
SAVEBIT_B11
	MOVLW	b'00000001'	;gp5=1 2nd bit =1
	IORWF	A11,1		;inclusive or on A11 1st bit , result <00000011>/<00000001>
	RLF	A11,1		;rotate left to make 4 bit table check up
	RLF A11,1		;rotate again to become 4bit
	GOTO	SHAFT_2		;back to 3rd bit check
SAVEBIT_B10
	MOVLW	b'00000000'	;gp5=0 2rd bit =0
	IORWF	A11,1		;inclusive or on A11 1stbit  result <00000000>/<00000010>
SAVEBIT_A21
	MOVLW	b'00000001'	;gp4=1 3rd bit =1
	MOVWF	A21		;move to register A21
	RLF	A21,1		;rotate left to make 4bit table check up
	GOTO	SHAFT_3		;back to 4th bit check
SAVEBIT_A20
	MOVLW	b'00000000'	;gp4=0 3rd bit =0
	RLF	A21,1		;rotate left again
SAVEBIT_B21
	MOVLW	b'00000001'	;gp5=1 4th bit = 1
	IORWF	A21,0		;inclusive or A21 3rd bit
	IORWF	A11,0		;inclusive or with A11 to make up 4th bit
	GOTO	DIRECTION	; check on direction
SAVEBIT_B20
	MOVLW	b'00000000'	; gp5=1 4th bit =1
	IORWF	A11,0		;IOR with A11 to make up 4th bit
	GOTO	DIRECTION	;check for direction
DIRECTION
	CALL	TABLE_1		;direction look up table
ANTI_CLOCKWISE
	DECF	ORIGINAL_PWM,f	; anti-clockwise means decrease on pwm cycle
	MOVLW	d'255'; to prevent decrease more than 0 cycle condition, turn to 255 cycle
	SUBWF	ORIGINAL_PWM,0; sub original_pwm
	BTFSC	STATUS,C; check on carry flag if cycle >0 , carry appears
	GOTO	RELOADZERO; if it is 0, reload zero to original_pwm register
	GOTO	NORMAL;if not, continue to save
RELOADZERO
	MOVLW	d'0'; load 0 to pwm due to over decrease happened
	MOVWF	ORIGINAL_PWM; move to register
	GOTO	NORMAL;continue to save pwm
NORMAL
	CALL	SAVE_PWM	; call save pwm routine to save pwm data for recall on start up
 	GOTO	RESTART_PWM	;return from save and continue to generate pwm signal
CLOCKWISE
	MOVLW	d'1'; clockwise means increase on pwm cycle
	ADDWF	ORIGINAL_PWM,0; add to the register to prevent over increment happned(more than 255)
	BTFSC	STATUS,C;it will turn to 0 cycle if over increment
	GOTO	RELOAD255; reload 255 cycle
	INCF	ORIGINAL_PWM,f	;increase pwm if no over increment condition happened
RELOAD255
	MOVLW	d'255'; load 255 to resigter due to over increment to 0 in w register
	MOVWF	ORIGINAL_PWM; move to resigter
	RETURN
;**** DIRECTION TABLE****************************
TABLE_1:
	ADDWF	PCL,1	; add the result to pc, result is from 4th bit generated
	GOTO	RESTART_PWM	; no increment nor decrement
	GOTO	ANTI_CLOCKWISE	; decrease on pwm
	GOTO	CLOCKWISE	;increase on pwm
	GOTO	RESTART_PWM	;
	GOTO	CLOCKWISE	;
	GOTO	RESTART_PWM	;
	GOTO	RESTART_PWM	;
	GOTO	RESTART_PWM	;
	GOTO	RESTART_PWM	;
	GOTO	CLOCKWISE	;
	GOTO	RESTART_PWM	;
	GOTO	CLOCKWISE	;
	GOTO	RESTART_PWM	;
	RETURN
	END
hi, for all who has the experience of using MPLAB ICD2 or PICKIT2,
i was trying to program my chip, it appears the warning shows as the title before i programme the chip(PIC12F629)
Above is my code, i simulated my code in MPLAB SIM, it worked fine and as expected. i ignored the warning and programme the code into the chip, but it doesnot work on my hardware.
If someone free and like to challenge, please read on my code and correct me if i m wrong. I am willing to learn.
Thanks!
PS: i tried to program the chip with a simple blinking LED program, it also did not work out on hardware...
Is it my code problems or the programming problem?... :o
I've not studied your program, but does the jump table at the end cross a 256 byte boundary? - best to place it near the start of the program so you are guaranteed it doesn't.
I think i know why my programme did not work, is it because of the calibration value of the internal osc that i m using...
because i found out i erased the initial value...is there anyway to recover the factory calibration value?
by the way, if i wan to use a new PIC, how can i prevent the calibration value not being erased when i need to programme the PIC ?
this is because everytime before i need to programme the PIc, i will need to erased the PIC memory, and doing so will delete the calibration value as well.
therefore, i need some advice on preventing the code being deleted during erasing the memory.
Thanks!
I would expect any decent programmer software to read and restore the calibration value, or as a minimum prompt and ask if you wanted to do so - it shouldn't erase it without telling you.
Your ICD2 should leave the value alone by default. If you have access to a PICkit2 it has a recalibration program for many PICs.
PS you shouldn't need these lines...
GPIO EQU H'0005'
TRISIO	EQU	H'0085'
Did you by accident overwrite a space in eeprom that is used for the chip ID / etc, can't remember if it is stored there?
oh thanks...i will try to use a pickit2 to recalibrate the value ( how to recalibrate the value using pickit2)??
btw, what kind of software can i use?
cos i am using MPLABv8.10
can i use it to recalibrate my osc value?how?
thanks...
