I'm not sure if this is what these forums are for and I'm pretty sure my title makes me a moron but... I'm looking for some help figuring out how to power these parts for a programmed interval:
https://www.amazon.com/Aquatec-8800-Booster-Pump-Transformer/dp/B003ZJMSEY
https://www.freshwatersystems.com/p...ff-solenoid-valve-with-qc-fittings-24vac.aspx
The idea is that the pump will turn on for a programmed time. Then, one after the other, each solenoid opens for a fraction of that time; with a bit of overlapping. Afterwards, everything is off for a set time.
I'm clueless what part(s) to look for and figured you all could point me in the right direction. I could conceivably have 200 solenoids per pump. So I'd like any thoughts on handling future expansions. I'd also be thrilled if this could be networked to remove the display and controls cost.
Thanks ahead for any thoughts!
