Hi
Can anyone indicate the pin of the attached relay circuit.
pin 1 = coil pin (-)
pin 2 = coil pin (+)
Pin 3 = Common contact (C)
Pin 4 = Normally-Closed contact
Pin 5 = Normally-Open contact
Did i state those pin correctly?
Basically i am doing room light controller. My relay should turn off all the time and if there is a people goes in the room the relay will turn on the light. So from this case the light bulb should connect to NO right? Instead of NC.
Lastly i had modify the circuit and its show below
Can the new modified circuit worked same as the above circuit?
Thanks for the reply
