sorry was so busy trying to do my program this few days. I have done the look up table for my buggy. Both the top and the bottom of the sensor.
; Program: [Stepper_Motor.asm]; Written by: Foo DF; Date: 29-Aug-2006
; This program configures PortC RC0-7 as OUTPUT to control the L293D Motor Control Board
; ************* HEADER **************************************************************
LIST p=16F876 ;PIC16F876 is the target processor
#include "P16F876.INC" ;Include header file
__config H'3F39' ;Osc=XT; WDT=Off;
;Power Up Timer=Off; Brown Out Detect=Off
;LVP=Disabled, Flash Program Write=Enabled,
;Data EE Read Protect=Off; Code Protect=Off
;************** File Register Variable use ******************************************
cblock H'20'
NUMBER
d1 ;use for Delay subroutine
d2
d3
d4
SENSOR
TOP
BOTTOM
TOP_motion
BTM_motion
endc
; ************* Reset Vector ********************************************************
org H'00'
clrf STATUS
movlw 0x00
movwf PCLATH
goto Initial
; ************* Port B and C I/O Initialisation *************************************
Initial
bsf STATUS,RP0 ; Select BANK 1
; banksel TRISB
movlw B'00000000' ; Set PortB to O/Ps
movwf TRISB ; PortB setting is done!
movlw B'11111111' ; Set PortC to I/Ps
movwf TRISC ; PortC setting is done!
movlw B'00000000' ; Set PortA to O/Ps
movwf TRISA ; PortB setting is done!
movlw B'00000110'
movwf ADCON1
; ************* Main Program *******************************************************
banksel PORTA
Start
Enable_BS170 movlw b'00110000'
movwf PORTA
call SENSE
call TOPP
call BTM
goto Start
SENSE movfw PORTC
movwf SENSOR
movwf PORTB
return
TOPP
movfw SENSOR
andlw b'11110000'
movwf TOP
swapf TOP,w
call Top_Table
movwf PORTA
return
BTM
movfw SENSOR
andlw b'00001111'
movwf BOTTOM
swapf BOTTOM,w
call BTM_Table
movwf PORTA
return
; *************** Delays ***********************************************************
Delay_100us movlw 0x1F
movwf d1
again2 decfsz d1,f
goto again2
goto $+1
return
Delay_50us movlw 0x0F
movwf d1
again3 decfsz d1,f
goto again3
return
Top_Table
addwf PCL
retlw b'00110000' ;stop (Stop,stop)(0000)
retlw b'00110001' ;Left Turn (stop,forward)(0001)
retlw b'00110010' ;right turn (move,stop)(0010)
retlw b'00110011' ;reverse (reverse, reverse)(0011)
retlw b'00110100' ;turn left (stop,move)(0100)
retlw b'00110101' ;forward (move,move)(0101)
retlw b'00110110' ;turn right(move,stop)(0110)
retlw b'00110111' ;turn left(stop,move)(0111)
retlw b'00111000' ;turn right(move stop)(1000)
retlw b'00111001' ;turn right(move stop)!1001)
retlw b'00111010' ;turn right(move stop)(1010)
retlw b'00111011' ;turn right(move stop)(1011)
retlw b'00111100' ;forward (move move)(1100)
retlw b'00111101' ;turn left (stop move)(1101)
retlw b'00111110' ;turn right (move stop)(1110)
retlw b'00111111' ;stop (stop stop)(1111)
BTM_Table
retlw b'00110011' ;forward (move, move)(0011)
retlw b'00110100' ;forward (move,move)(0100)
retlw b'00110101' ;turn left (stop,move)(0101)
retlw b'00110111' ;forward(move,move)(0111)
retlw b'00111000' ;forward(move move)(1000)
retlw b'00111001' ;turn left(stop move)!1001)
retlw b'00111011' ;forward(move move)(1011)
retlw b'00111111' ;move (move move)(1111)
; ************* End of the program ************************************************
END ;End of the program
This is what i have come up with so far. But i am having trouble connecting the look up table to the motor. My buggy has 2 motors as well. The problem i have is the sub routine for the motor. i know i need to declare a new sub routine which is motor. but how do i continue up from there
