Replaced an AOSmith 1/2 HP motor w/ 6 wires with a Dayton 1HP (Model# 1TMY5 - Farm Duty Motor, 1 HP, 1725, 115/230v, 56H www.daytonmotors.com) - problem is that the new motor has 8 wires (P1, P2, T1, White, Yellow, Black, Orange and Red) and I can't seem to figure out the correct wiring schematic to connect into the contractor with the four wire harness (Yellow, Grey, Purple and Blue) that was supplied with the control box. This entire setup is for an industrial shop door (Liftmaster Model T) and I have the power coming off of a 20amp breaker and then four control wires to a control box (Open, Close, Stop). I have the single phase wiring diagram (T - Industrial-Duty Trolley Operator for Standard Lift Sectional Doors) but it only shows a two wire configuration connection to the motor.
Maybe I have the wrong motor? I'm in a "pickle" as the weather is turning here in KS and need to get this thing working ASAP. Thanks in advance
