i am working on a kenwood amplifer and the ground and power outlets both have power going through them a sugestions on what could be the prolbem.
thank you
when i hook up the ground wire it sparks there is power going through the ground location if the power wire is hooked up. if the ground wire is hooked up then there ground going through the power block.
when the power is hooked up it flows all throught amp nothing is grounded iven the speaker outputs. if ground is hooked up at same time major sparks. If the ground is hooked up the entire amp is ground. Which ever one i hook up flows throught all the componets. The remote is the only thing on the amp that is not affected it can be hooked up at all times.
thank you
