[VHDL] - Problem while using while loop inside a case.need help..
I am working with Quartus II on an cyclon 1 altera device.
My programming language is VHDL.
I am trying to write a Sync Decoder that recognize when the data_in pin input is "111000" - serial input.
Here is my code:
I get the Error (10536): VHDL Loop Statement error at manchester_encoder.vhd(31): loop must terminate within 10,000 iterations.
Can someone explain to me why I cant compile this file?
I want to program it into a cyclone I processor.
10x alot,
Asaf
Here is my code:
Code:Library ieee; use ieee.std_logic_1164.all; Entity Decoder is port( d_in: in std_logic; clk: in std_logic; d_out: out std_logic_vector(31 downto 0) ); end entity; architecture behave of Decoder is TYPE state_type is (sync_detecting,decoding); signal state:state_type; CONSTANT SYNC : std_logic_vector := "111000"; signal i : integer range 0 to 6; BEGIN process(clk,d_in) variable sync_detected_n : std_logic; Begin if rising_edge(clk) then case state is when sync_detecting => sync_detected_n := '1'; i<=0; sync_detection : while i<5 loop if rising_edge(clk) then if d_in = SYNC(i) then i<=6; else i<=i+1; end if; if i=5 and d_in<=SYNC(i) then sync_detected_n := '0'; end if; end if; exit sync_detection when i<=1; end loop; if sync_detected_n = '1' then state<= sync_detecting; else state<= decoding; end if; When decoding=> d_out<="11111111111111111111111111111111"; end case; end if; end process; end;
10x alot,
Asaf
