It depends upon what type of oscillator you have in the hardware.Gaston said:i am trying to program a pic with nigel's led tutorial. im also using the programer on his site. im not sure what all of the different oscillator types are or which one to use.
If you fiddle with the check boxes in WinPicPro you'll see the config word change. Reload the HEX file and they will change back to the instruction code values.i see the config word is the same as in the instruction code.
Nigels tuts using the 16F628 use the internal oscillator. When the 16F876 is being used then it needs a crystal oscillator.It depends upon what type of oscillator you have in the hardware.
