Help putting together some off the shelf low voltage heating components
abapper
Hi everyone..
I'm looking to put together a small personal project and need help with the components.
Ideally, I'd need all the components to fit inside this box.
In an approximate 5" x 6" x 3" plastic box (2-3mm thick with no other insulation at this point) where the volume will be ~50% consumed by an existing object, I want to raise the internal air temperature from 72F to about 75F.
The heating element should cycle on / off as the temp reaches 75F max and 72 min.
This would be used 100% indoors and ambient (external to my enclosed box) temps would never dip below 60F while the heat box is in use.
I wanted to include a thermostat / controller / heating element / rechargeable battery pack inside the box. The size of the box can vary a little to accommodate all these components.
I was looking at using components such as these:
  1. thermostat / controller
  2. heating element
But I am confused if I can find a small enough battery to power these as they are 12V.
Should i be looking for lower voltage versions to accommodate a smaller USB C rechargeable battery? Are there similar components that operate on lower voltage?
Is there anything I'm missing?
thanks!
You say that the room is never below 60°F, what is the maximum temp of the room?
the max temp of the room would be 72F. so basically, I want to heat the interior of the box from 72 to 75F
How long do you expect the batteries to last? And how often is the room cooler than 72°F? And what is the teypical temperature of the room?
Ideally, I would like to only have to charge the battery once per day but with a max use of 8 hours (let's call this overnight). I 'd like that once the interior of the box reaches desired temp, the controller would cycle off to help reach the 8 hour utilization time.
The room outside of the box may get colder - let's say 65F but I'm hoping that the somewhat enclosed nature of the heat box will make it easier to keep the interior box temp above 72F
