rajesh.mahapatra
Dear Sir,
Here I am assigned a project where I need ur useful suggestions.
I have to do the following things prior to start my project and for that purpose suggest me.
1. Choose a microcontroller(8/16/32 bit)
2. ADC whose input range should be between 0 - 10 volts range and must have more than 3-channels for following purpose:
a) the output of pressure transducer in terms of voltage will be used by one channel whose voltage range is between 0-10 V.
b)Output of Temperature transducer will be used by other second channel whose voltage range is between 0-5 V.
c)Weight Transducer will be used by third channel whose voltage range is between 0-5 V.
3.LCD interfacing(text only) 16x2.
4.keyboard (Logitech keyboard or any alphanumeric) having alphanumeric and up-down keys.
5.data Logging facility for storing atleast 1000 data values( RAM for that purpose).
>Operater name
>Company Name
>date and time
>Reading data
6.connectivity to PC through RS-232.
7.Printer interface.
Kindly suggest me, which ADC and Microcontroller I should use.Also, for best precision it is required that I should not convert 0-10V range of ADC to 0-5 V. Suggest me an ADC having 0-10V input range and having more than 3 channels.
So please suggest me and mail me. Waiting 4 ur most valuable suggestions.
With regards
Thank You sir,
Rajesh Mahapatra
>Operater name
>Company Name
>date and time
>Reading data
With regards
Thank You sir,
Rajesh Mahapatra
