antknee
I'm currently learning about the LM3886 audio amplifier and a non inverting board with gain of 11. The chip has a minimum GBP of 2MHz but they are rated at up to 8MHz. THe load is just a resistor of 4 ohms and i'm working in the frequency range above audio.
I understand gain bandwidth product as for example this: Gain (11) x bandwidth (100KHz) =< GBP (2MHz)
What I'm finding is the output is also voltage dependant. And it is this bit I don't understand.
For example if I drop the input voltage down to 0.1V I can go up to 500KHz.
How is GBP also voltage dependant?
I have also noticed clipping in some circumstances. The reason for that came to me at that time but has since vanished. Why does that occur?
Thanks for your help.
Antknee.
Antknee.
