help usart and LCD
justas12
Hi, i am working with RFID project, but im not good in programming. The deal is that i have source code, where read rfid card bits are send to usart, but i dont need it. I need to send it to LCD. Idont know how to configure lcd. can anyone help me and edit the source code?
Look below for a example from Mikro C Pro:
 * Project name:
     Lcd_Test (Demonstration of the LCD library routines)
 * Copyright:
     (c) Mikroelektronika, 2008.
 * Revision History:
     20080930:
       - initial release;
 * Description:
     This code demonstrates how to use LCD 4-bit library. LCD is first
     initialized, then some text is written, then the text is moved.
 * Test configuration:
     MCU:             PIC16F887
     Dev.Board:       EasyPIC5
     Oscillator:      HS, 08.0000 MHz
     Ext. Modules:    LCD 2x16
     SW:              mikroC PRO for PIC
 * NOTES:
     - Turn on LCD backlight switch (SW9.7) on development board.(board specific)
// LCD module connections
sbit LCD_RS at RB4_bit;
sbit LCD_EN at RB5_bit;
sbit LCD_D4 at RB0_bit;
sbit LCD_D5 at RB1_bit;
sbit LCD_D6 at RB2_bit;
sbit LCD_D7 at RB3_bit;
sbit LCD_RS_Direction at TRISB4_bit;
sbit LCD_EN_Direction at TRISB5_bit;
sbit LCD_D4_Direction at TRISB0_bit;
sbit LCD_D5_Direction at TRISB1_bit;
sbit LCD_D6_Direction at TRISB2_bit;
sbit LCD_D7_Direction at TRISB3_bit;
// End LCD module connections
char txt1[] = "mikroElektronika";
char txt2[] = "EasyPIC5";
char txt3[] = "Lcd4bit";
char txt4[] = "example";
char i;                              // Loop variable
void Move_Delay() {                  // Function used for text moving
  Delay_ms(500);                     // You can change the moving speed here
void main(){
  ANSEL  = 0;                        // Configure AN pins as digital I/O
  ANSELH = 0;
  C1ON_bit = 0;                      // Disable comparators
  C2ON_bit = 0;
  Lcd_Init();                        // Initialize LCD
  Lcd_Cmd(_LCD_CLEAR);               // Clear display
  Lcd_Cmd(_LCD_CURSOR_OFF);          // Cursor off
  Lcd_Out(1,6,txt3);                 // Write text in first row
  Lcd_Out(2,6,txt4);                 // Write text in second row
  Delay_ms(2000);
  Lcd_Out(1,1,txt1);                 // Write text in first row
  Lcd_Out(2,5,txt2);                 // Write text in second row
  Delay_ms(2000);
  // Moving text
  for(i=0; i<4; i++) {               // Move text to the right 4 times
    Lcd_Cmd(_LCD_SHIFT_RIGHT);
    Move_Delay();
  while(1) {                         // Endless loop
    for(i=0; i<8; i++) {             // Move text to the left 7 times
      Lcd_Cmd(_LCD_SHIFT_LEFT);
      Move_Delay();
    for(i=0; i<8; i++) {             // Move text to the right 7 times
      Move_Delay();
You should notice the bits at the top which define where the LCD is connected and the port direction.
Then this:
will replace the UART1_Init() routine.
Then you can use LCD_Out to write the text out to the LCD.
Definition of the LCD_Out:
void Lcd_Out(char row, char column, char *text);
LCD_Cmd writes a command to the LCD display.
This is defined as:
void Lcd_Cmd(char out_char);
where out_char is the command, and is one of the following:
Lcd Command Purpose
_LCD_FIRST_ROW Move cursor to the 1st row
_LCD_SECOND_ROW Move cursor to the 2nd row
_LCD_THIRD_ROW Move cursor to the 3rd row
_LCD_FOURTH_ROW Move cursor to the 4th row
_LCD_CLEAR Clear display
_LCD_RETURN_HOME Return cursor to home position, returns a shifted display to its original position. Display data RAM is unaffected.
_LCD_CURSOR_OFF Turn off cursor
_LCD_UNDERLINE_ON Underline cursor on
_LCD_BLINK_CURSOR_ON Blink cursor on
_LCD_MOVE_CURSOR_LEFT Move cursor left without changing display data RAM
_LCD_MOVE_CURSOR_RIGHT Move cursor right without changing display data RAM
_LCD_TURN_ON Turn Lcd display on
_LCD_TURN_OFF Turn Lcd display off
_LCD_SHIFT_LEFT Shift display left without changing display data RAM
_LCD_SHIFT_RIGHT Shift display right without changing display data RAM
Note, all of the above was taken from the Mikro C Manual, so it's very easy to find.
Hope this helps!
Wilksey.
i use pic18fxxx i dont really remember, firstly i tried with pic16f887, but ai need 32Mhz, so i changed it and now there is pic18fxxx. i use mikroc compiler
