help using tables
josi
hi! i'm learning how use how to display on a 7-segment using a pic 16f877. i'm tryin to call a table and display the values via portD wich is connected to the 7-segment! can anyone check my code coz it's not workin! thanx
LIST	     p=16F877
#include    <P16F877.inc>
__config    _XT_OSC & _PWRTE_ON & _WDT_OFF &_LVP_OFF
;*****Equates**********************************************
status       equ 03h
PortA        equ 05h
PortD        equ 08h
TRISA        equ 85h
TRISD        equ 88h
count0       equ 25h
count1       equ 26h
count2       equ 27h
pcl          equ 02h
pclath       equ
;******Main Program****************************************
    org         00h
    bsf         status,RP0
    movlw     B'11111111'       ; set portA as input
    movwf    TRISA
    movlw     B'00000000'       ; set PortD as outpout
    movwf    TRISD
    movlw	    D'6'
    movwf	    ADCON1
    bcf         status,RP0
start
   call        Table
   movwf    PortD
   goto       start
Table
   retlw     b'11101111'            ;display 0
   call       delay
   retlw     b'10001001'            ;display 1
   call       delay
   retlw     b'11010111'
   call       delay
   retlw     b'11011101'
   call       delay
   retlw     b'10111001'
   call       delay
   retlw     b'01111101'
   call       delay
   retlw     b'00111111'
   call       delay
   retlw     b'11001001'
   call       delay
   retlw     b'11111111'
   call       delay
   retlw     b'11101111'
   call       delay
delay                                  ;delay routine
   movlw  03h
   Movwf  count2
Loop
  decfsz   count0,1
  Goto     Loop
 Decfsz  count1,1
 Goto     Loop
 Decfsz  count2,1
 Goto     Loop
 Return
 end
You can't have delays in the middle of your table. You have to access your table, write it to the port and then do a delay.
I tidied your code to how I think it should be. See if this works,
		list	p=16F877
count0		equ	25h
count1		equ	26h
count2		equ	27h
digit		equ	28h
		org	00h
		bsf	STATUS,RP0
		movwf	TRISA
		movwf	TRISD
		movlw	D'6'
		movwf	ADCON1
		bcf	STATUS,RP0
		clrf	digit
start		movfw	digit
		call	Table
		movwf	PORTD
		call	delay
		incf	digit,F
		movfw	digit
		xorlw	d'10'
		btfsc	STATUS,Z
		clrf	digit
		goto	start
Table
		addwf	PCL,F
		retlw	b'11010111'
		retlw	b'11011101'
		retlw	b'10111001'
		retlw	b'01111101'
		retlw	b'00111111'
		retlw	b'11001001'
		retlw	b'11111111'
		retlw	b'11101111'
		movlw	03h
		movwf	count2
Loop		decfsz	count0,1
		goto	Loop
		decfsz	count1,1
		goto	Loop
		decfsz	count2,1
		goto	Loop
		return
		end
I added the variable digit to keep track of what to display. Try running the above in the simulator to get an idea of how it is working. You might want to rem the call delay line when your simulating.
In addition to Pommie's advise.
Relook at the segment patterns,
Im assuming PORTD.0 = seg 'a' D.1= seg 'b' etc....
Mike.[/QUOTE]
i tried what u said mike but it's not workin, i'm getting one segment on at a time! i don't know what to do!
That code should work. The code is written to use a common cathode display, is this what you are using? If you are using a common anode display then swap the 1s and 0s in the retlw lines.
If it still doesn't work then you need to post a schematic.
