cbr900rr316
basiclly what I want to do is use a remote control to turn on and off a togle switch under the dash of my car. I want the togle or relay to just allow power to flow thru or not. I do not want it to add power to the line etc.. so basically if i was trying to remote control a set of lights the controller and reciever would have power that would flow or not flow.. thats not my case..
i'm trying to use a remote and a reciever to bascially go to fuse box and eitehr allow current to flow or not via a latching device. I assume a regular auto relay in this case would work.. but how do I wire the relay so that no additional power flows thru the switch. I basically want it as if the fuse box had a fuse in it at one moment and the next it did not. I want to use a remote and reciever to do this so i assume i wire the reciever to ground and power and have that power the relay to allow flow thru the fuse line i'm trying to togle. previously i ran 2 wires to the fuse and put a togle in between now i want to do it with a remote and reciever instead of running wires thru the fire wall of my vehicle. any help would be greatly appreciated... thankx in advance.. jb boston mass!
