Hello guys, one of my friends bought a car amp but wants to use it as a regular amp for some home speakers. The problem that we encountered is that we cannot power it on. This is the AMP
I recommended him to get a 12V 8A DC power supply. Like this one
Got all the audio input wiring done and when I pluged it in we realised that we need a power antenna lead? which comes from a car, as it is a CAR amp.
MY question is, can we power this amp without a whole car audio system?![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
In the manual of the amp says something about 5V to the REMOTE input:
Manual
"The head unit's power antenna lead is logic level
output (+) 5V, negative trigger (grounding type),
or cannot sustain (+) 12V when connected to
other equipment in addition to the vehicle's power
antenna. If any of the above conditions exist, the
remote turn-on lead of your BBX-T600 must be
connected to a switched power source (ignition) in
the vehicle. Be sure to use a 3A fuse as close as
possible to this ignition tap. Using this connection
method, the BBX-T600 will turn on and stay on as
long as the ignition switch is on."
Tell me what you think about this, should he return it, or can this thing be powered from a buck converter or something else.
Manual
