Malakesher
Hello let me start straight away by saying I know very little about electronics as I’m sure you will notice. I have been looking through your FAQ and at some of the site linked. I am trying to learn.
Anyway I started this whole learning electronics because I want to modify this timer I have (or rebuild from scratch if there are a lot of changes).
Anyway this allows me to pulse for up to 5 seconds and then pause for up to 60 seconds then repeat. Now I need to improve these lengths of time and as far as I understand using higher resistance potentiometers (I hope that’s spelt right) would do this.
So first of all is that correct?
Then secondly I want to up the times to 10 mins pulse and 7 hours pause which is a huge leap, and I'm totally guessing here, but that may be too much of a stretch for just changing the pots.
So is there anything else I should change on this to achieve what I'm after?
Here is the build guide I hope it has all the information that you need to help me.
Link to full manual
Thank you very much for helping and if there is anything else you need to know I do have the timer with me so if the information is on a component I can tell you it.
Link to full manual
