Help with Constant Current Source
rajesheee_244
Hi...can anyone please help me out? I need to design a current source with current ratings range 1mA - 50mA and with a compliance voltage of 50v. Can anyone help me in designing the circuit? Thank you in advance.
CONSTANT CURRENT SOURCE
The output will be limited to 1mA by using a red LED and 1k for Re.
The output will be limited to 100mA by using a red LED and 10R for Re.
Use a pot to vary the output.
Since 330R is ground the transistor is switched ON.
LED voltage is equivalent to V(BE) + V(Re)
Assume an Red LED needs 2V.
2V = 0.7V + VRe
VRe = 1.3V ---- voltage across (Re)
Using ohms law to (Re)
1.3 = I X 1000R
I = 1.3mA
