JunglePython
I am a total newbie with pics and I am trying to get my head around assembly.
I have been reading "PIC in Practice" by D.W. Smith.
In it he uses a 0.5 second delay routine.
This routine dosent make sense to me, could someone please
explain it to me.
The circuit uses a 32.768kHz xtl, prescalar is /256, timer is 1/32 secs.
As I see it the routine will * clear tmr0
*put tmr0 in w
*subtract 16 from W
*see if answer is 0 if so skip next instruction and then return to program, otherwise it will goto LOOPB.
As I understand it once TMR0 is reset it will start count up with each clock cycle. In this instance that would be 1/32 of a second. Does this mean that for this to really be a 0.5 second delay that it should only take 16 clock cycles from the time the delay is called to the time it returns to the program.
Does this routine acheive this?
explain it to me.
;0.5 second delay.
DELAYP5 CLRF TMR0 ;START TMR0.
LOOPB MOVF TMR0,W ;READ TMR0 INTO W.
SUBLW .16 ;TIME - 16
BTFSS STATUS,ZEROBIT ;Check TIME-W =0
GOTO LOOPB ;Time is not =16.
RETLW 0 ;Time is 16, return.
*put tmr0 in w
*subtract 16 from W
