hi, i was wondering if anyone could help me.
for my AS project i have designed a very simple combo lock,
its basically just some 555 monostables and some 2 input NAND gates, one input of the nand gate is connected to Vs, so when the 555 output goes high the output of the nand with go low, the ouput of the nand gate it connected to the trigger of the 555 with a switch inbetween so that u have a set time you can press the switch before the first 555 turns on, this happens for 4 switches.
I am trying to replace the switches with a keypad, but the only keypad i could get hold of was a matrix one which i dont know how to use, you anyone explain how i could use it?
here is the keypad - **broken link removed** and it also comes with 2 pdf's with 2 different pin outs **broken link removed** **broken link removed**
thank you
thank you
