Help with my project please
I need help with the following project:
Fixed frequency divider by 33. The counter used will have the synchronous R input. Only circuits will be used
from the HCT/HC series. The oscillator will provide two rectangular signals with frequencies of 5Hz and 435kHz respectively
and a manual clock signal.
The power supply model and the clock generator needs to be like i did in the project. I need someone to help explain how to do this properly, in proteus.
  • projaction.rar
this is the image we get for the projet, on the left is "oscillator", middle "7 bit counter" on the right Q0 to Q6 are 7 LED's and dows is a "status detector" or something like this.
Another user is doing the exact same project...
See here:
The other student using an analog method where you need a tolerance stackup error less than 1/87000 to reset will find it expensive to find RC components trimmed to better than this tolerance.
So there are several methods to generate 5 Hz (not kHz) and 435 kHz from a manually tuned input clock.
Input 435 kHz
1. Design a synchronous counter for 87,000 counter as 43500 & 2
If you need an odd number counter it implies you will need to use both edges of the clock to *2f.
Check 33 times , release once. then twice with experience. ( and 5 times with senior's moments:p)
The unrar applications like 7-zip cannot compromise your OS by just opening a RAR file to examine the contents. Your advice is more sensible for file types that modify the OS.
Looks like earlier WINRAR versions had that problem.....
I doubt any are true positives these days. One just has to look at the benign file extensions to tell what isn't enclosed. :cool:
Perhaps eons ago https://www.pcmag.com/news/winrar-has-serious-flaw-that-can-load-malware-to-pcs
7-zip is my goto unRAR app.
"I doubt any are true positives these days"......
Seems like there are more concrete actions and changes on this, recent I might add, 2023 timeframe.
