Help with programming in C (Darts Scoreboard)
MspLee
Was wondering if anyone has any knowledge in programming in c for the use of a darts scoreboard......details to follow
Yeah so it doesnt detect an actual dart thrown, you just enter the score into a 4x4 keypad and displays Players 1's score on an LCD and Player 2's score on another LCD
Here are the two schematics along with the project, the first is the keypad attached to an msp430 acting as an encoder to detect the keys pressed...the second is the microcontroller (which is also linked to the encoder by using data lines) attached to the two LCDs
  • Schematics (Individual).zip
Its the code for doing the calculations in the microcontroller and then code for sending and recieving values from the keypad
If you are using C the basic maths will do... add subtract multiply an divide are already available with standard libraries....
Have you any code you have written???
This is what I have so far in terms of code. You will see I am struggling towards the end.
C:
unsigned long initialDartScore = 501, dartScore = 0;
  // LCD module connections
sbit LCD_RS at RB4_bit;
sbit LCD_EN at RB5_bit;
sbit LCD_D4 at RB0_bit;
sbit LCD_D5 at RB1_bit;
sbit LCD_D6 at RB2_bit;
sbit LCD_D7 at RB3_bit;
sbit LCD_RS_Direction at TRISB4_bit;
sbit LCD_EN_Direction at TRISB5_bit;
sbit LCD_D4_Direction at TRISB0_bit;
sbit LCD_D5_Direction at TRISB1_bit;
sbit LCD_D6_Direction at TRISB2_bit;
sbit LCD_D7_Direction at TRISB3_bit;
// End LCD module connections
void init(void) ()
   trisb=0b00000000;
   portb=0b00000000;
   Keypad_Init;  //Initialize Keypad on portc
   Lcd_Init;  // Initialize LCD on PORTB
   Lcd_Cmd(_LCD_CLEAR);  // Clear display
   Lcd_Cmd(_LCD_CURSOR_OFF);  // Cursor off
   Lcd_Out(1, 1, "501");
   Lcd_Out(2, 1, "Enter Score:");
   return;
char newValue;  //Define newValue
unsigned short kp=0;
int numb=0;
int enter=0;
int input(void)
   numb=0;
   do
      kp = Keypad_Key_Click();
      if (kp==1)  //if keypad button one is pressed then display 1
        {  // on LCD.
        lcd_out(2,16,"1");
        numb=1;  //  data transfer to numb int
      if (kp==2)
        lcd_out(2,16,"2");
        numb=2;
      if (kp==3)
        lcd_out(2,16,"3");
        numb=3;
      if (kp==5)
        lcd_out(2,16,"4");
        numb=4;
      if (kp==6)
        lcd_out(2,16,"5");
        numb=5;
      if (kp==7)
        lcd_out(2,16,"6");
        numb=6;
      if (kp==9)
        lcd_out(2,16,"7");
        numb=7;
      if (kp==10)
        lcd_out(2,16,"8");
        numb=8;
      if (kp==11)
        lcd_out(2,16,"9");
        numb=9;
     if (kp==14)
        lcd_out(2,16,"0");
        numb=0;
     lcd_out(2,16," ");
      if (kp==15)  // # key  ENTER KEY
        enter=1;
   while (enter==0);
   enter=0;
   return;
char HUNDREDS[4];
char TENS[4];
char UNITS[4];
char RESULT[4];
char  keypadPort at PORTD;  //create char array to store keypad data
int x=0;  //create int to store data
int y=0;  //create int to store data
int a=0;  //create int to store data
int b=0;  //create int to store data
void main(void)
   init();  //goto initialize function to set up ports, etc
   while(1)
     /////////////////////////Hundreds I/P///////////////////////////////////////////
     input();  // jump to keypad input function ( save address in the stack)
     x=numb;  // return from function (after getting address from the stack)
     if(x>1)  // value limiter to prevent angles over 180 degs
       x=1;
     IntToStr(x, HUNDREDS);  //int to string convertor for LCD
     Lcd_out(2, 11, HUNDREDS);  // HUNDREDS O/P to LCD
     /////////////////////////Tens I/P///////////////////////////////////////////////
     y=numb;  // return from function (after getting address from the stack)
     IntToStr(y, TENS);  //int to string convertor for LCD
     Lcd_out(2, 12, TENS);  // TENS O/P to LCD
     /////////////////////////Units I/P//////////////////////////////////////////////
     input();
     a=numb;
     IntToStr(a, UNITS);  //int to string convertor for LCD
     Lcd_out(2, 13, UNITS);
     ///////////////////////////Maths to add up HUNDS, TENS and UNITS////////////////
     x=x*100;
     y=y*10;
     b=x+y+a;
     if(b>180)  // value limiter to prevent scores over 180 points
        b=180;
     IntToStr(b, RESULT);  //int to string convertor for LCD
     Lcd_out(2, 11, RESULT);  //points O/P to LCD
     while(1);
        //dartScore gets value from key press (0...9)
        //after new value is entered for dartScore a flag named newValue is set
        if(newValue) {
        if(dartScore >= initialDartScore) dartScore -= initialDartScore;
        //Convert dartScore to string using IntToStr() and display on LCD
        //Clear newValue flag
        newValue = 0;
Your last while(1); statement causes a hang!! as there is a ; after the statement... Code will sit at this line forever..
In your input routine you have an unconditional piece of code that overwrites all the other conditions..
C:
     lcd_out(2,16," ");
C:
     lcd_out(2,16," ");
Thanks, I hadn't even noticed that.
The main problem is getting this bit of code to work:
while(1);
if(newValue) {
newValue = 0;
I am trying to get it to start at 501, then subtract a number, say 100, the automatically display 401. If you know what I mean?
As a pointer.. I would have a 16 key keypad.. 0~9 D T B and enter.
I would have a key routine that returns a key if one was pressed.
A second routine that would read the values and correct for (D) double (T) treble or (B) bull..
So entering " D 4 enter " would auto deduct 8 from the total, or print "Too much" if total exceeded keeping the score as is..
That sounds a better idea actually, but I am new to programming so it would take to long for me to work out how to do it. Thank you anyway
As with CrhisNI my darts scoreboard seems to be the same, i have the keypad attached to a prototype board connecting to the encoder....LEDs are acting as output values in binary...code as follows:
// Encoder
#include "msp430g2452.h"
#include "intrinsics.h"
// Function prototypes
void bdelay(int j);
char keyread(void);
void main( void )
  // P1.3,P1.2,P1.1,P1.0 are inputs (Rows)
  // P1.7,P1.6,P1.5,P1.4 are outputs (Columns)
  // Interrupt happens when any row input goes high - key is pressed
  P1DIR = 0xf0;                   //Configure P1 - lower nibble is an input
  P1SEL=0x00;                     // no special functions for P1 port lines
  P1IE=0x0f;                       // interrupts on lower nibble of P1
  P1IES=0x00;            // interrupt on rising edge
  P1OUT=0xf0;
// Port 2 is used as an output
  P2DIR = 0xff;                     //Configure P2 as output lines
  P2SEL=0x00;                     // no special functions for P2 port lines
  P2IE=0x00;                       // no interrupts  for P2 port lines
  P2OUT =0x00;                  // 0 on un-used lines
  // Stop watchdog timer
  WDTCTL = WDTPW + WDTHOLD;
  __enable_interrupt();
while(1)
   __low_power_mode_0();
void bdelay (int i)
  i=i*500;
  while(i!=0)i--;
#pragma vector=PORT1_VECTOR
__interrupt void PORT1__ISR (void)
  char row=0x99,col=0x99,key=0x00;
  char numbers[]={0x01,0x04,0x07,0x0f,0x02,0x05,0x08,0x00,0x03,0x06,0x09,0x0e,0x0a,0x0b,0x0c,0x0d}; // Array for assigning of buttons
//debounce for 20ms approx
bdelay(20);
// find row  - which one is HIGH?
  if((P1IN&0x01)==0x01)row=0x00;
  else if((P1IN&0x02)==0x02)row=0x01;
  else if((P1IN&0x04)==0x04)row=0x02;
  else row=0x03;
// find column - write LOW to each Column, in turn and check if Row(s) go LOW
P1OUT=0x7f;  // try Column 3 - P1.7
bdelay(2);
if((P1IN&0x0f)==0x00)col=0x03;
else
{P1OUT=0xbf; // try Column 2- P1.6
bdelay(2);
if((P1IN&0x0f)==0x00)col=0x02;
else
{P1OUT=0xdf;// try Column 1- P1.5
bdelay(2);
if((P1IN&0x0f)==0x00)col=0x01;
else
{P1OUT=0xef;// try Column 0- P1.4
bdelay(2);
if((P1IN&0x0f)==0x00);col=0x00;
}}}// Restore output to normal
P1OUT=0xf0;
//If multiple keys are pressed either row or col is still 0x99
//Ignore key(s), completely, if this is the case
if((row!=0x99)&(col!=0x99))
//Form new (4-bit) key code from its column and row position
key=row|(col*4);
// Data available (P2.7) HIGH and output key read (P2.3....P2.0)
P2OUT=(numbers[key])|0x80;
// wait until key(s) released
  while((P1IN&0x0f)!=0x00)
  // Data Available low( key not pressed), last valid key value shown
  P2OUT=numbers[key];
  // end of routine
P1IFG=0x00;
