Hi I need help with connection PS-2 with PARALLAX
Boris
On data output all time I have High level and nothing changed
More information
I think you aren't going to have much luck getting a response with such little information. Can you explain in more detail? What item do you have from Parallax?
For that matter, what's a PS-2?.
A PS-2 was an old IBM computer series, do you mean that?, and if so, what part are you talking about?.
Or do you mean the Playstation 2?, often abbreviated to PS-2.
maybe PS2 port(also known as mouse\keyboard port)
Re: More information
I use BS2 PARALLAX.I tried to connect joystick Sony play station-2 with controller BS2(PARALLAX) using software from magazine VOLT& NUTS. Nothing works. I did not have signal from data output ,which goes from joustick. Do you have any idea what to do?
Did you read the article carefully? Normally, when they present a project, it's because it works. Check all you have done and compare it with the article, so you'll know if you made an error or if you changed a part.
