Hi-Tech C 18 Family, Interrupt never ends!
kylemaes
Banned
Hey, I have this interrupt that literally never ends I've debugged it all and it seems to be fine... I have never had it exit before and would like to fix it because I want the Main function to do stuff aswell no just a looping interrupt...
Here is my code: (Interrupt is at the bottom so you dont have to seach everywhere)
#include <p18f2550.h>
#include <delays.h>
#include <adc.h>
#pragma config  PLLDIV = 12, CPUDIV = OSC1_PLL2, USBDIV = 2, FOSC = HS, FCMEN = OFF, IESO = OFF
#pragma config  PWRT = ON,  BOR = OFF, VREGEN = ON, WDT = OFF, PBADEN = OFF,  LPT1OSC = OFF,  MCLRE = OFF
#pragma config  STVREN = OFF,  LVP = OFF, DEBUG = OFF
#define E RA5
#define RS RA4
#define RW RA3
int interruptnum = 0;
int huns;
int remain;
int tens;
int ones;
int fare;
int huns2;
int tens2;
int ones2;
//__EEPROM_DATA(1,2,3,4,5,6,7,8); how to write to eeprom without using programmemory
const char ScreenData[39] = {
0x41, //A 0
0x42, //B 1
0x43, //C 2
0x44, //D 3
0x45, //E 4
0x46, //F 5
0x47, //G 6
0x48, //H 7
0x49, //I 8
0x4A, //J 9
0x4B, //K 10
0x4C, //L 11														//CHARACTER DEFINITIONS!
0x4D, //M 12
0x4E, //N 13
0x4F, //O 14
0x50, //P 15
0x51, //Q 16
0x52, //R 17
0x53, //S 18
0x54, //T 19
0x55, //U 20
0x56, //V 21
0x57, //W 22
0x58, //X 23
0x59, //Y 24
0x5A, //Z 25
0x20, //SPACE 26
0x3A, //: 27
0x30, //0 28
0x31, //1 29
0x32, //2 30
0x33, //3 31
0x34, //4 32
0x35, //5 33
0x36, //6 34
0x37, //7 35
0x38, //8 36
0x39, //9 37
0x25 //% 38
void Strobe_LCD()
	E=1;
	_delay(4000);
    E=0;
void Busy_Flag()
  RW = 1;     //read mode
  while(RB7);     //Loop until finished
  RW=0;       //default to write mode...
void Write_LCD(unsigned char d,unsigned char x)			//USE "Write_LCD(tabledata,1=cap0=lowercase);" (IF number Cap selection must equal 0!)
	char z = 0x00;
	if(!x)
			z=0x20;
	TRISB=0x00;
	PORTB=d+z;
	Strobe_LCD();
	Busy_Flag();
	TRISB=0xFF;
void AddressDisplay(unsigned char c)
  Busy_Flag();    //check LCD ready
  RW = 0;     //write mode
  RS=0;       //command mode
  PORTB=c;     //place data on data port
  TRISB = 0;    //PORTB output
  Strobe_LCD();
  RS=1;
  TRISB = 0xFF;    //PORTB input
void lcd_init()
	Write_LCD(0x38,1);
	Write_LCD(0x0C,1);
	Write_LCD(0x01,1);
const char programnametext[16] = {
2,14,12,15,14,18,19,4,17,26,26,21,4,17,27,30
/*Co  m p   o  s  t  e  r        V  e  r :   2*/
programname()
	char a = 0;
	char b;
	char c;
	Write_LCD(0x01,1);
	RS = 1;
	while(a != 16)
			if((a==14) | (a==0) | (a==9) | (a==10) | (a==15) | (a==11)){c=1;}
			Write_LCD(ScreenData[programnametext[a]],c);
			c=0;
			a++;
	RS = 0;
void main()
	TRISA=0;
	TRISB=0;
	TRISC=0;
	ADCON0=0;
IPEN = 1; /* Set Priorities */
GIEL = 0; /* disable low priority interrupts */
GIEH = 1; /* enable high priority interrupts */
T1CKPS1 = 0;
T1CKPS0 = 1;															//INTERRUPT SETUP TIMER0
TMR1CS = 0; /* Increment every instructrion cycle */
TMR1IP = 1; /* Make high priority interrupt */
TMR1ON = 1; /* Enable the timer */
TMR1IE = 1; /* Enable timer1 interrupt */
	lcd_init();
	programname();
	while(1)
			RS=1;
			AddressDisplay(0xC0);			//FANSPEED
			Write_LCD(ScreenData[5],1);
			Write_LCD(ScreenData[0],0);
			Write_LCD(ScreenData[13],0);
			Write_LCD(ScreenData[27],1);
			Write_LCD(ScreenData[28+huns],1);
			Write_LCD(ScreenData[28+tens],1);
			Write_LCD(ScreenData[28+ones],1);
			Write_LCD(ScreenData[38],1);
			RS=0;
void interrupt isr(void)
TMR0IF=0;
You are enabling timer 1 and clearing the flag for timer 0. As soon as the RETFIE is executed at the end of your ISR it will be called again because there is still the timer 1 interrupt to service.
Clear the flag for timer 1.
Thankyou so so much! You saved me hours and hours of trouble! That was the dumbest mistake ive ever made... Thanks again :P
REP+ for you :P
