High efficiency DC-DC
karas
need to figure what is the best time scheme I can use it for this circuit to achieve high efficiency (soft switching)
This bidirectional DC-DC vin 60vdc and vout=600VDC Po=6Kw, so is there is any suggestion and also I need help to simulate it the circuit to figure the efficiency through simulation
  • H-bridge.asc
Welcome to ETO.
If by 'soft switching' you mean the power FETs/IGBTs won't be switched fully on and fully off as quickly as possible, then the FETs will get hot and the circuit will have low efficiency.
"soft switching" usually is about resonant switching. Where the turn on or turn off stress is very low. I have done designs where the FETs are turned on with 0V and 0I and turned off at 0V and full current.
can you please advice how can achieve soft switching, and can you draw the timing if you can please
