Jules_Theone
I have designed and built a flyback SMPS circuit for a high temperature motor controller board with the following spec:
40v - 75v input
5v @ 300mA
10v @ 10mA
5v @ 50mA (with isolated gnd)
I'm using a LM5020MM-2 controller, Wurth Elektronik power over ethernet tranformer part number 749119133, FCD4N60 MOSFET for the power switch. The circuit is attached.
The circuit powers up ok, with stable 5.0v regulated, 10.4v, 5.2v outputs with a 10mA loading. This works fine without any heating of components but when I increase the load to 150mA on the regulated 5v, both diodes on the outputs for the 5v and 10v get hot.
I have probed the outputs on a scope and found that there is a clear spike that corresponds to the switching from the power transistor. I think the spikes are what is causing the heating in the diodes, but don't have a solution.
Any ideas?
Thanks.
40v - 75v input
5v @ 300mA
10v @ 10mA
Any ideas?
Thanks.
