High(ish) Voltage Regulator
KingKrak
Hey,
I'm building a circuit that is powered off a rectified 3 phase supply (when rectified is about 600V). The control part of the circuit is 5V.
I'm having a few problems figuring out how to easily provide a 5V power source to the control circuit. Normally I would just use a 5V regulator, but normally I have power supplies that are 12V to 24V.
I can't use a transformer (into one of the AC phases) because of tight size and cost restrictions. I thought about using a zener diode in series with a resistor across the 600V load, but the control circuit will probably draw around 100mA and the zener probably won't be able to handle that.
I'm sure somebody out there knows a better way to do this...
For low currents you can use a high voltage, film capacitor in series with the AC power line feeding rectifiers and a shunt regulator. But this will not isolate the circuit from the line so is a hazardous circuit and it must have an interlock so no one can access the circuit while power is applied.
For isolation you must use a transformer.
Hey,
Use a FET as a regulator. A great circuit exists in "The Art Of Electronics"
The art of electronics - Google Books
I actually used a modified version of this circuit (components changed and the OPAMP referenced changed to be a Zener with some high-power/voltage resistors as a burn). I also added a crude close-loop feedback system to ensure tighter regulation of the output 15V (via another zener and a bjt to shunt the main zener)
It had to provide 15V from a "supply" of 30V -> 750V (nominal was 350V).
This works very well. I was pulling ~15mA from it and a TO220 FET was bolted to some aluminium nearby and it experienced a temprise of ~7C settled out after 20min at 600Vdc
For higher power you might want to concider paralleling up the FET's to spread the power disipation between 5 or 6 such devices
If you don't mind dissipating the power, you could also use a power resistor in series with a shunt regulator (yes, a Zener diode to ground makes a shunt regulator). This avoids having to use high voltage transistors.
So how do you plan to dissipate 60 watts of heat with a power resistor in a space smaller than a transformer that has to only handle a .5 watt load?
A 1.5 VA transformer is very small and would easily fit inside a 1.5 inch cubed space. A 60 watt resistor and or heat sink is many times larger than that!
I agree with tcmtech; trying to dissipate 60W in that way is absurd; consider for a moment the amount of heat a 60W lightbulb produces...
