Monster_Magnet
I have been doing quite a bit of research and have yet to find out how a gas generater outputs 10kWatts-15KWatts @ 220VAC and 120VAC. Ive found numerous schematics on building a 12VDC to 120VAC or 220VAC inverters but they all range from 300Watts to 1000Watts. Its stated many times that the 12V battery will explode if the wattage is increased any further.
My goal was to mount a 10hp-11hp horizontal shaft motor to a base structure and install a pulley to run a 65Amp internally regulated alternater. The alternater would then connect to a battery, and the inverter to supply 120VAC and 220VAC to the face where I planned on mounting the controls(Switches) and recepticles(Plugs).
If someone could explain how such a high wattage can be acheived without sacrificing the required voltages and amps to run delecate equipment I would be in your debt. This is a project Im researching as a possible senior project and was hoping to build it big enough to run a welder/plasma cutter that runs on 220VAC @ 23Amps.
