ElectroDummy
Hi guys,
I just found old flashlight and due to inability to use any of the new batteries I decided to create new one from 4xAA batteries (NiMH aku AA;1,2V/2000mAh Panasonic "Eneloop").
I created simple circuit and used old flashlight switch in it. It works just fine. Then I added DC charging connector and connected it to the new accumulator with the 2 wires from the circuit. It means the connector is under voltage when the flashlight is charged.
Today I plugged in the charger and while holding the flaslight in my hand I accidentally touched the metal stove cover and "I felt the current" and got a little burned (just felt like it is very hot in the fraction of a second I made the contact).
I used multimeter to measure current between flashlight and the stove cover and it was 3,65 mA. Of course the flashlight is made of metal.
How I could solve this problem? Should I izolate all of the components of the flashlight or use some ground?
Thank you for any tips!
